Old 01-17-2011, 05:08 PM
woolanddie is on a distinguished road
DELTA VH3600 Z axis backlash
I have a DELTA VH3600 knee mill that has a lot of backlash in the Z axis. Can anyone tell where I can find drawings for the Z axis mechanism or how to eliminate the backlash? All help is appreciated.
Old 01-18-2011, 05:22 AM
Some disassembly required.
The ball screw is attached to the quill by means of a connecting block. It is fastened on by two bolts. These bolts are in behind the ball bearing housing. You have to take apart the entire assembly to get at them. If these screws are loose or have developed slop you must retighten them. My connecting block is made out of brass so it developed some play. I am putting a couple of steel washers under the heads so as to help reduce some wear.
Delta 20 4 axis dingo0722 Dynapath 4 11-19-2010 11:25 AM
X axis backlash SX3 kenealym Syil Products 7 04-27-2010 09:30 PM
Z axis backlash. wyc Syil Products 21 09-04-2008 02:20 PM
backlash DELTA 40 rhurt Tree 3 04-15-2007 01:02 AM
'Z' Axis Backlash ? andy_ck87028 DIY-CNC Router Table Machines 7 09-07-2006 08:45 PM
