Old 01-15-2011, 03:54 PM
Spinnetti is on a distinguished road
DYI 4th axis advice?
I have a big HF round column milldrill and 4axis servo controller. I'm looking to do the 4th axis now and can't make up my mind. I could just put a motor on my big "super spacer", but its really too big. I'm thinking:
1. Use a 5C spinner collet chuck a and add a 5c backed chuck and a servo motor to it - I see them on ebay for $40
2. Use the head from a mini-mill and put a servo motor on it - LMS has them for $120.
I'm thinking I'd like to make it a high speed spindle so I can do turning on the mill too, so wasn't sure if the 5c chuck would be sturdy enough for that.
Also, anybody know how many rpm a typical servo will turn, and how big a one I might need? to use both as a index head and lathe drive? I saw the thread/youtube video about where somebody did this already, so that was good info too.
Old 01-15-2011, 09:50 PM
Scanfab is on a distinguished road
My Tsugami Fanuc servos spin 2000 rpm-you can read that from the nameplates. Are you on a tight budget? ebay has some 4th axis' for sale that have the correct type of faceplate/bearing needed and put your own servo on it for tightest fit.
Old 01-16-2011, 10:28 AM
Well, a traditional 4th axis is geared really low. I'd like to go belt drive with a minimal reduction, or is that not practical for slot cutting and the like?
Old 01-16-2011, 10:34 PM
I would not try to cut against a belt, 4th axis has a worm gear for two reasons, for resolution and it's ability to hold its position while taking on the machining forces. If you were only drilling on center(Y axis) with small tools and no need for accurate positioning, then maybe a belt would do. Machines with both lathe option and 4th axis positioning have two motors doing the work, a spindle motor and a servo for the 4th axis work that engages and disengages with an M code(M50 and M51 on my Tsugami).
Can you use two motors- one belt driven and one work gear with servo?
Old 01-17-2011, 12:42 AM
judleroy's Avatar
judleroy is on a distinguished road
You could also consider using a motor with a break. The break would hold your position for milling and still allow you to run up to speed for turning. You might want to think about multiple pulleys so you can gear down for good torque on 4th axis work.
Judleroy
Old 01-17-2011, 09:55 AM
Judleroy
My 4th axis has a brake straight on the faceplate(inside the housing) and the braking force does NOT go through the gear.. This way you can drill a 1" hole 10 inches off center without turning the axis..
Old 01-17-2011, 10:47 AM
Thanks for the feedback..
I had considered both the two motor and the brake, though perhaps two gear ratios and a brake for the really heavy stuff would do it. I don't have a lot of 4th axis needs, though if I had it I might find the uses. Right now, I'm thinking a lathe headstock for free run turning, with a seperate geared or timing belt driven 4th axis function for light 4th axis, and a brake clamp for fixed 4th axis might be a good combo...
Need Help!- Advice on 5-Axis and ERP Lawsonmh15 General Metalwork Discussion 0 01-10-2011 01:27 PM
Need Help!- Advice on 5-Axis and ERP Lawsonmh15 General Metal Working Machines 0 01-10-2011 12:45 PM
Advice on 3 Axis Kit spjuenger Joes CNC Model 2006 1 08-31-2009 04:19 PM
Z axis need advice Kev DIY-CNC Router Table Machines 2 07-19-2007 07:11 PM
Motorized Z Axis - Advice ADucci Linear and Rotary Motion 1 07-02-2007 10:56 AM
