Old 01-12-2011, 09:13 AM
fourperf is on a distinguished road
spin indexer
Hi Guys, would anyone happen to know how many degrees apart the 10 holes are on the vernier plate of a spin indexer?
The outer plate has the 36 holes at 10 degrees apart.
I cant wrap my head around the math.
thanks
Mark
Old 01-12-2011, 09:50 AM
keebler303 is on a distinguished road
I'm not sure what is used on commercial deals but its easy enough to figure out. Here is a list of where the holes would go and what angles you will get:
hole at 0 deg. That will lock in your 0,10,20, etc.
hole at 11 deg. That will lock in your 1,11,21, etc.
hole at 22 deg. That will lock in your 2,12,22, etc.
hole at 33 deg. That will lock in your 3,13,23, etc.
hole at 44 deg. That will lock in your 4,14,24, etc.
You should see a pattern now. Basically each hole is 1 degree apart but since that would put the holes on top of each other, you space them one hole (10 deg) plus 1 deg.
Matt
Old 01-12-2011, 10:27 AM
Thanks a lot Matt. That make complete sense. The spin indexer I have been looking at has equally spaced holes, but I cant wrap my head around that.
Mark
Old 01-12-2011, 10:36 AM
Those holes are equally spaced!
Moving ring has 36 holes evenly spaced.
Stationary has 10 holes one every 11 degrees.
You could also do 1/2 deg indexing by putting 20 holes one every 10.5 deg.
Matt
Name:	spin index.jpg‎
Old 01-12-2011, 12:41 PM
Oh, ok. Got it. Sorry. It took a minute. Makes complete sense now. Thanks a lot.
Mark
X3 Spindle won't spin bergeson Benchtop Machines 6 05-19-2010 11:42 PM
Motor Won't Spin DeusExMachina Hobbycnc (Products) 8 12-10-2008 06:23 PM
Need to spin something in the Z originator Mechanical Calculations/Engineering Design 5 01-10-2007 07:05 AM
Will a Cat 40 holder spin without a key? moldcore General Metal Working Machines 4 11-27-2006 09:19 AM
Why do we spin the screws? Jcadwell CNCzone Club House 5 05-02-2004 10:33 PM
