Old 01-11-2011, 04:21 PM
Jett_Rigby is on a distinguished road
What desktop CNC ??
I've been loooking at some DIY CNC kits and there's just so many its confusing.
I've looked at:
Sable 2015. I like that it's made of metal.
ZenToolWorks 12x12 It's made of PVC but it seems to have a nice construction. Cheap. Anti-backlash nuts, takes a palm router as a spindle.
Fireball V90. Another machine that's fairly cheap. It's large which I like but I don't know about it's performance. I like that it has a metal bed option instead of that cheap MDF.
And the CNC 3040 which are all over ebay.
I'm sure I'm missing a few other awesome CNC machines but this is what I could find so far. Any other machines recommended?
My needs are to cut aluminum and maybe brass. More accurate is better because I would be cutting parts. I have a small budget. Up to $1500 around. The less I can spend the better though.
Old 01-19-2011, 08:28 AM
shauttra is on a distinguished road
I am interested in CNC 3040 too, looks nice, but what about its performance, accuracy?
I need it for small wood works. Is it better than home built machine?
Old 01-19-2011, 08:50 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Contact user "gio666", he has some beaut routers and he's in Toronto.
-Jason
Old 01-20-2011, 06:00 PM
2slaps is on a distinguished road
You missed one cheap cnc router.
ZENBOT CNC ROUTER
I'm in the same boat as you! I can't decide on which one to buy. As of now... I'm leaning more in to the fireball v90 (base/frame for $599 and I can get the other things off ebay) The CNC 3040 from ebay looks well built but since it is from china...i don't know if the customer support and warranty will be a problem or not. Let me know which one you pick.
Old 01-20-2011, 07:34 PM
roninB4 is on a distinguished road
If you're going to cut nameplates or something that doesn't require a greater depth of cut than 1/32 then I won't be able to comment on any of these. If your parts will have cuts/geometry greater than 1/32 then none of these are suitable for precision work. They're all too flimsy to take a real cut and using a hand held moto-tool in place of a real motor driven spindle is optimistic at best in any metal. They may work in some plastics or wood but an 1/8 bit isn't going to chew out much material. Sorry if this isn't what you wanted to hear but I wouldn't expect much out of any of these unless your parts are:
Thin
Plastic
Wood
Just engraving
Vibration will greatly affect the finish, a hand held moto-tool is too wimpy to take a substantial cut. JMO
Help me pick machines for small hobby-ish shop. joshuadreed General Metal Working Machines 9 09-06-2010 12:17 AM
Considering a (first) machine build, a small desktop mill footloose Open Source CNC Machine Designs 6 05-25-2010 01:12 AM
Considering a (first) machine build, a small desktop mill footloose General Metal Working Machines 0 05-21-2010 04:03 AM
Small Desktop CNC Kit yngndrw Commercial CNC Wood Routers 9 03-21-2009 09:26 AM
Help to pick small (not mini) CNC Lathe 5axis General Metal Working Machines 5 02-03-2004 05:35 PM
