Old 01-11-2011, 12:00 AM
nickster is on a distinguished road
Question Fanuc 5t over current field light on
Hello Guys
Im a newbe here and need lots of help! I have a Fanuc 5-t control with a Miyano 7BC. Just got it hooked up and i can't get the spindle to work I have been trying to start it in MDI at only 150rpm and it turns over about a half turn and then kicks out. on the drive board there is a over current light on. I have cleaned the tack and motor brushes, and checked to make sure there are no blown fuse's. The coolant pump is working ok so im guessing it is hooked up correct. Any body out there?
Problem- "over current/ field loss" on spindle acceleration or deceleration rolandkra Fanuc 11 01-19-2011 06:49 PM
Problem- Overcurrent/Field loss on spindle deceleration Fanuc 5t Nakamura and phase converter rolandkra 5T/5M 3 01-10-2011 01:09 PM
6T-B spindle problem Over current/field loss atex57 Fanuc 1 07-05-2010 11:35 PM
Fanuc 6t (No CRT,red light) jachilli Machine Problems, Solutions , Wireless DNC, serial port 0 06-10-2006 12:20 PM
Fanuc 6m 401 on X TGLS light is lit?? mt92 Fanuc 3 04-04-2006 05:35 PM
