Old 01-10-2011, 06:55 PM
bobrob is on a distinguished road
indicating in a drill on a cnc lathe
It takes me forever is there a way if getting drill close b 4 i indicate it in ?? i tried eyeing it but it still takes me forever , i dont have a probe. on machine
Old 01-10-2011, 07:01 PM
Put a piece of stock in the chuck and face it down to leave a tiny tip right at the center. Now bring the drill up and align the point with this tip.
Alternately, face the stock off completely to center, bring the drill in and align it as close as possible to center then very gently touch the drill to the rotating stock. If it is very close the drill will deflect slightly and find its own center. Just jog the X back and forth until you don't see any deflection as the drill settles into the dimple it has made.
Old 01-10-2011, 08:27 PM
Cruiser is on a distinguished road
Better yet is start with a piece of stock to dial in then change it to the drill !
Also, I always orient my bits so the drill cuting edges are perpindicular to the axis then start a drill .001 increments and watch which flute takes off a bit of chip then jog toward the chip and move into part again looking for the chip and move tward chip, then when the chips are equal your centered ! this is easiest of all and will get you going in a hurry.
Don
IH v-3 early model owner
Need Help!- what is a good way to get close b4 indicating a drill in on a lathe bobrob General Material Machining Solutions 0 01-10-2011 06:51 PM
Indicating magnetic base englishsunset Want To Buy...Need help! 0 11-20-2010 04:21 PM
Dial Indicating a hole Arich0908 Benchtop Machines 4 04-25-2010 10:37 AM
Need Help!- setting a drill &/or a c/drill on a cnc lathe warren01 CNC Machining Centers 3 01-20-2010 01:31 PM
Indicating sqr stock in 4 jaw chuck Shotout General Metalwork Discussion 10 05-14-2007 08:13 AM
