Old 01-09-2011, 06:37 AM
zoeper is on a distinguished road
13" harrison lathe help
I recently bought this 13" harrison lathe (metric version with 6mm Leadscrew)
The machine is also fitted with a taper turning attachment.
I need to get a set of changewheels and screwcutting chart for this machine, as well as the cross slide screw for the taper turning attachment (No. 1 in the drawing. I got part 2 with the machine)
According to the parts list the required gears are:
127T
38T
33T
32T
30T
28T
27T
26T
Screwcutting chart (part number 552, I have 551)
I would need to get the threadcutting chart (a copy or picture would be fine also) and the set of changewheels. (as long as i can get the chart, i might be able to source gears locally)
For the taper turning attachment i require the cross slide screw (No 1 on the drawing) with the splines on the operator end. (Part number L16-12-23 Metric)
Harrison in the UK is of absolutely no help and they would not even look in their archive for a copy of the plates.
Does anybody have a copy of the threadcutting chart and/ or a set of changewheels and special cross slide screw for this machine?
Any help would be much apreciated.
Pieter
Old 01-12-2011, 12:53 AM
Does anybody know of a supplier of parts for these Harrison lathes?
Need Help!- Harrison Lathe Backup kcho Fanuc 12 05-23-2012 01:39 PM
alpha 550 lathe harrison 1996 arleydrive Fanuc 5 04-19-2011 04:37 PM
Need Help!- Harrison Lathe bugzpulverizer General CNC (Mill and Lathe) Control Software (NC) 2 05-19-2009 05:01 AM
Need Help!- Harrison Lathe completely crashed! b23 General Electronics Discussion 0 02-02-2009 10:32 AM
Harrison VS450 CNC flat bed lathe Fudd General Metal Working Machines 1 11-14-2006 06:31 AM
