Old 01-07-2011, 03:34 PM
zephyrmachine is on a distinguished road
CNC Lathe Floor Space Requirements
Hey guys. I just bought two CNC lathes, one Haas SL30T (1999) and a Mazak QT30 (1998). I'm a bit tight on space in my shop, so I want to place the lathes facinbg each other with the back of one facing a wall. I want the lathe to be as close to the wall as possible while maintaining enough space to access the service panel, and the machines are quite a distance away so I cant really go and measure them. I was wondering if anyone has one of the lathes can tell me how much space I need behind either machine. Any help would be appreciated. Thanks in advance.
Old 02-14-2012, 12:58 AM
wizard is on a distinguished road
If by service panel you mean the electrical control panel, you need to check code.
By that I mean local electrical code. You could need 4 or more feet of space between the wall and the panel. The actual distance is based upon voltage and other factors.
Even if you are talking a mechanical access panel you would be well advised to leave plenty of space. Note that putting the machines back to back can often save space while keeping you compliant. I have no visual references for these two lathes so I can't help with actual hardware layout. Often though lathes are installed perpendicular to walls to maximize space and optimize work flow. Of course this can be an issue with bar feeding machines.
Obviouslyi don't know what your plant looks like right now but you may find yourself benefiting from a reorganization of machine tools.
yellow lines on floor arond lathe mycoolbeard Safety Zone 2 08-29-2009 02:27 AM
Space requirements for SHG1212 john_t_h Excitech routers 3 07-29-2009 04:49 AM
Space in Frederick MD dgapilot Mentors & Apprentice Locator 0 02-25-2008 06:58 PM
Anyone else have space issues? cxixer DIY-CNC Router Table Machines 6 10-14-2007 10:37 PM
Paper space Model space ?? CNCadmin Autodesk Software (Autocad, Inventor etc) 10 05-29-2003 06:07 AM
