Old 01-07-2011, 12:50 PM
david rendon is on a distinguished road
workholding headache on a CNC lathe
Hello everyone, here's a good one...
I'm turning a R.17 on a 5.500" long hex bar (stainless) .... first I tried using a hex collet but the holding lenght of the collet is very short so the part swivels like crazy ...
second, I drilled a machinable collet and it works ok, but the problem is that I need to find the right spot where the hex bar is better centered.
Another problem is that the Radius goel all along the bar, that means that I have to turn this in 2 diferent operations...
Any ideas on how to hold this long hex bar?????
Old 01-08-2011, 12:55 AM
jeffrey001 is on a distinguished road
You could buy a hex shape spring collet.
Jeff
Old 01-08-2011, 05:31 PM
leggazoid is on a distinguished road
Here are the steps I use to hold hex material centered in a 3 jaw chuck with soft jaws.
1: Install jaws with enough sticking past the OD of chuck for cleanup.
2: Clamp on a suitable size chuck ring or material laying around.
3: Turn OD of jaws.
4: Take jaws out and install machined end down in milling vise.
5: Mill the 3 jaws to the same height.
6: Put jaws in lathe chuck on the proper serration to clamp hex.
Old 01-08-2011, 05:40 PM
jimmytightpants is on a distinguished road
I would just stick it in a 3jaw and center drill it. flip it around and do the same to the other side. then turn between centers. flip around to finish the rest of the OD.
Old 01-10-2011, 11:04 AM
I tried using an hexagonal spring collet, but the part swivels a lot !! .... I believe this is a good trick you guys might find interesting ....I ended up holding the part using a ER-16 collet extension (used regularly for milling purposes) .... It worked great!! (take a look at the pics) ....... cool isn't it ???
ID:	123549   Click image for larger version
ID:	123550   Click image for larger version
Old 01-13-2011, 08:03 PM
gdwood3rd is on a distinguished road
Call Hardinge Inc. in Elmira, NY - get hold of Rick Schoener and tell him George told you to give him a call. He will take care of you.
V2XT Headache M99 Dan Bridgeport and Hardinge Mills 8 03-22-2010 08:16 PM
Online Workholding Shop for Workholding mtadirect Product Announcements & Manufacturer News 0 08-19-2009 09:37 AM
Need Help!- Communication Headache! oldtigger Bridgeport and Hardinge Mills 1 07-28-2009 07:28 PM
Workholding in the lathe Terk General Metalwork Discussion 5 09-27-2006 09:19 PM
Milling Angle Headache! ADVANCED MACH. General Metalwork Discussion 9 12-06-2005 07:46 PM
