Old 01-02-2011, 11:36 AM
mi2011 is on a distinguished road
miniature end mill holder?
I'm new to CNC and Milling and started last year with a Sherline CNC mill. I'm trying to acquire some Miniature Carbide End Mill. (E.g.
Amazon.com: Niagara Cutter MES230 Miniature Carbide End Mill, Uncoated (Bright), 2 Flutes, Stub Square End, 0.0525" Cutting Length, 0.035" Cutting Diameter: Industrial & Scientific Amazon.com: Niagara Cutter MES230 Miniature Carbide End Mill, Uncoated (Bright), 2 Flutes, Stub Square End, 0.0525" Cutting Length, 0.035" Cutting Diameter: Industrial & Scientific
I found what I wanted but now I'm a bit unsure what's the best way to mount these miniature end mills.
I found the following (not cheap). (E.g. Microcut Carbide Micro End Mills ) So I was wondering what others use and what works.
Thanks for you feedback.
Regards, Michael
Old 01-04-2011, 11:40 AM
rowbare is on a distinguished road
Those seem to have a 1/8" shank so use a 1/8" collet to hold them. Sherline also has 1/8" end mill holders.
bob
Old 01-04-2011, 06:36 PM
Bob,
thanks for the info. I will check it out. Is it wise to place a end mill with a full round shaft in an end mill holder? I was left with the impression that you use the end mills with a flat shaft side (not sure that the term is) and mount them in an end mill with the set screw.
Regards, Michael
Old 01-05-2011, 02:42 PM
They are called Weldon shanks. You could always grind a small flat on the shank but my preference is to go with a collet for that small a cutter. That should minimize runout.
bob
Old 01-07-2011, 08:44 AM
Hi Bob, thanks for you reply. I will put in an order for the 1/8" collect. Thanks for your help. Regards, Michael
Tags
end mill holder, miniature, sherline
mill holder sources Freddy Bastard Haas Mills 2 11-05-2010 09:32 AM
R-8 End Mill Holder ranchak Metal Working Tooling 13 01-29-2009 05:06 PM
End mill holder question jim_stoll Benchtop Machines 2 11-19-2007 03:35 PM
R8 X3 spindle - end mill holder won't fit :mad: messar Benchtop Machines 3 02-02-2006 07:32 PM
How would i mill copper/delrin with miniature tooling? Please help a novice. touser General Metalwork Discussion 5 01-05-2006 07:20 PM
