Old 01-01-2011, 01:43 PM
ironofeden is on a distinguished road
x axis moving too far
hello we have a esprit lightning d plasma cutter, the x axis moves 0.02mm per mm too far when traversing in either jog mode or within a program can anyone suggest why this might be
cheers
benjamin
Old 01-03-2011, 08:23 AM
EPTech's Avatar
EPTech is on a distinguished road
Does the machine do this all of the sudden? Have you changed something to parameters? Did you replace an encoder?
Old 01-04-2011, 11:22 AM
Hello, i have not changed parameters or encoder the machine cuts and traverses like this either in manual jog mode or in a program, do you know if it is possible for one axis to move too fast and overrun itself?
Old 01-04-2011, 04:43 PM
EPTech's Avatar
Another possibility is that some fluid has spilled and soiled the encoder. Can you find any traces of fluid on the encoder housing of the X motor? Careful. I have successfully cleaned the glass scale of an encoder before but it is risky business. Another possibility is that the encoder scale has come loose and got off-center due to vibration. In that case you need to replace it.
Newbie- correction on axis moving vagelism22678 TurboCNC 0 07-10-2010 10:27 AM
Help! Y-axis is moving up Dirkos Stepper Motors and Drives 2 06-03-2010 04:09 AM
(5 axis) Mach 3 not moving C B axis hamooteh Mach Software (ArtSoft software) 12 03-22-2010 12:49 AM
Is moving along Y unnecessary when using the 4th axis? Arquibaldo DIY-CNC Router Table Machines 8 07-18-2008 11:16 AM
Axis are not moving Reef Guy Mach Software (ArtSoft software) 4 09-13-2006 08:42 PM
