Old 12-31-2010, 08:26 PM
janbbeck is on a distinguished road
Retroactive build Log: DIY mill from surplus parts
At the beginning of the year, I decided that I wanted to build a CNC mill. I took pictures along the way, but not very many. Today, I took it apart and cleaned it to move it to another room, and took new pictures of the components. I now have a set that can be used to describe this build, I think. I am going to mix pictures of the current setup with pictures I took while I built the mill to fill in the gaps.
So I am basically writing a log of my progress over the past year. I did not have much money available, but my work has a machine shop and part of my fringe benefits is access to the shop and stock room. I was able to find quite a few nice things that saved me a pretty penny.
For this first post, I am going to include an image of the current mill as a preview of the log.
I am hoping that the info here helps or encourages someone else to build a cnc mill.
This machine currently works and has been making parts, including some for itself.
Old 12-31-2010, 08:40 PM
Ok, so this whole thing started by me finding a small x-y table that had only a motor on one axis.
All I needed to do is:
- scrounge up a second stepper motor and mount it
- find a controller board
- find an old PC with a parallel port to drive the board
A friend gave me several stepper motors as an extended loan as well as a controller board to drive them. There were some partial PCs in the stock room from which I built a 700 Mhz Pentium III with an extra parallel port card - for a total of 2 ports.
ID:	122600   Click image for larger version
ID:	122601   Click image for larger version
ID:	122602   Click image for larger version
Old 12-31-2010, 08:43 PM
Here a pic of the controller board. It is from a little while later, when I was cutting some plastic, so there are chips all over it. Of course at this time, there was no way of cutting yet, just the x-y table.
Old 12-31-2010, 08:50 PM
Scrounging around the stock room, I found an x-table, that seemed large and rigid enough to be my z axis.
In order to mount it vertically to the x-y table, I used a cast iron tooling plate and right angle cast iron knee, both of which I found in the stock room as well. so far no money has been spent.
ID:	122606   Click image for larger version
Old 12-31-2010, 09:00 PM
Next, I mounted the x-table to the knee.
Then, i mounted a Skill wood router I had in my garage to an aluminum plate. This plate was then mounted to the z-axis (previously called x-table).
I also mounted a CNC vice for a Roland CAMM machine. (I bought this one by mistake years ago, and it had been collecting dust in my garage)
I also taped a shopvac hose to a height gauge to have some dust extraction.
At this point I was able to make small parts. No money spent. A couple of weekends worth of work.
ID:	122608   Click image for larger version
Old 12-31-2010, 09:13 PM
The controller I had borrowed was quite old and limited to 3 axes. I wanted 4 axes or more, but was a bit hesitant to buy a board I found on ebay that could handle 5 axes at reasonable power. My wonderful wife made up my mind by buying the board for me.
I should not that in the previous post an autotransformer is visible, which I used to vary the speed of the router. Of course it too came from the stock room. From there also came a nice bench power supply to power the new controller board - but I only got that one as a loan :P
ID:	122610   Click image for larger version
Old 12-31-2010, 09:33 PM
In order to make my 4th axis, I decided on retrofitting a spin indexer, which I also scrounged up. The bracket to mount the stepper motor to the indexer is the first part the machine made for itself.
I was able to scrounge the drive belt and a pulley for the stepper motor. I then proceeded to machine an aluminum adapter to grab the spin indexer in the machine shop. I also put teeth into it to grab the belt, but somehow I got the spacing between teeth wrong. I then bought a plastic pulley off of amazon and mounted it to the aluminum. It cost me about $5
I also mounted an aluminum plate to the bottom of the indexer, so that I could clamp it into the vice with an offset.
This setup allowed me to use the 5-C collets from the machine shop to clamp to the work pieces.
This ends the part of the machine where I incurred almost no cost (hardware, at least - the mach3 demo only does 500 lines of code, but there is always emc2).
ID:	122612   Click image for larger version
ID:	122613   Click image for larger version
ID:	122614   Click image for larger version
Old 12-31-2010, 09:36 PM
at this point the machine could do small parts up to 4 axes. Here some test pieces. the smaller piece is from a broomstick or something that I put into a collet on the 4th axis.
Old 12-31-2010, 09:41 PM
In order to be able to machine larger pieces, I bought a 4 jaw chuck on ebay that fits into the spin indexer. Using a 4 jaw instead of a 3 jaw enables me to mount plates, not just cylindrical pieces.
ID:	122618   Click image for larger version
ID:	122619   Click image for larger version
ID:	122620   Click image for larger version
Old 12-31-2010, 10:06 PM
I found that the runout on the Skill router was awful. After some research I found that this is due to the collet and that precisebits.com makes precision collets for other routers.
Therefore, I ordered a Bosch router and a high precision set of collets to replace the crummy Skill. That reduced my runout to 0.0002 an inch down from the collet.
I should note that wood routers are universal motors. They are very unstable under changing load conditions. So I had a friend from the motor winding business show me how to rewire this thing as a shunt DC motor.
This was detailed in another thread:
http://www.cnczone.com/forums/genera...nt_torque.html
The whole operation was totally worth it. It does not slow down one bit from the preset RPM even with heavy cuts.
Name:	pictures Aug 2010 013.jpg‎
ID:	122623   Click image for larger version
Name:	pictures Aug 2010 014.jpg‎
ID:	122624   Click image for larger version
Name:	pictures Aug 2010 015.jpg‎
ID:	122625   Click image for larger version
Name:	pictures Aug 2010 016.jpg‎
Name:	pictures Aug 2010 017.jpg‎
ID:	122627   Click image for larger version
Name:	pictures Aug 2010 018.jpg‎
ID:	122628   Click image for larger version
Name:	pictures Aug 2010 019.jpg‎
ID:	122629   Click image for larger version
Name:	pictures Aug 2010 020.jpg‎
Name:	pictures Aug 2010 021.jpg‎
ID:	122631   Click image for larger version
Name:	pictures Aug 2010 022.jpg‎
ID:	122632   Click image for larger version
Name:	pictures Aug 2010 023.jpg‎
ID:	122633   Click image for larger version
Name:	pictures Aug 2010 024.jpg‎
Name:	pictures Aug 2010 025.jpg‎
ID:	122635   Click image for larger version
Name:	pictures Aug 2010 026.jpg‎
ID:	122636   Click image for larger version
Name:	pictures Aug 2010 027.jpg‎
ID:	122637   Click image for larger version
Name:	pictures Aug 2010 028.jpg‎
Name:	pictures Aug 2010 029.jpg‎
ID:	122639   Click image for larger version
Name:	pictures Aug 2010 030.jpg‎
ID:	122640   Click image for larger version
Name:	pictures Aug 2010 031.jpg‎
ID:	122641   Click image for larger version
Name:	pictures Aug 2010 032.jpg‎
Name:	pictures Aug 2010 033.jpg‎
  #11   Ban this user!
Old 12-31-2010, 10:16 PM
At this point, the 5x5 inch travel on the x-y table seemed puny, so I decided to replace it. As luck would have it I knew somebody who had planned on building a cnc mill and had already parts on hand, but decided against it. He sold me some pieces cheap and gave me others for free.
Among these pieces were two linear tables, a long one for my x and a short one for my y. I mounted them with the help of some aluminum plates to the tooling plate. On top of the y axis, I mounted a large aluminum plate to act as a table to clamp the workpiece, vice or 4th axis to.
ID:	122649   Click image for larger version
ID:	122650   Click image for larger version
ID:	122651   Click image for larger version
ID:	122653   Click image for larger version
  #12   Ban this user!
Old 12-31-2010, 10:27 PM
The reach of the arm holding the router on the z axis was now too short and so I built a longer one. Predictably, there was very little stiffness in this arrangements, so I reinforced the z arm to stiffen it up a bit.
I first tried to alumiweld the reinforcements, but my torch did not give nearly enough heat. When I took this to a friend to TIG weld it, he laughed at me saying that his welder did not have nearly enough amps to do this. He also mentioned that if we did use a heavier welder the workpiece would likely distort.
So instead I screwed the braces on.
ID:	122656   Click image for larger version
ID:	122657   Click image for larger version
ID:	122658   Click image for larger version
Surplus Store Router Build/Conversion juzwuz CNC Wood Router Project Log 12 05-04-2010 11:22 PM
VMC build & WTB: FANUC control parts gbowne1 Fanuc 1 05-07-2009 11:24 PM
New Machine Build- getting all the parts together for a CMM build roboticist Controller Cards 0 07-14-2008 08:18 PM
Looking for Haas surplus parts rubino2112 Haas Mills 1 11-23-2006 01:40 PM
Florida surplus cnc parts stores? Splint CNCzone Club House 12 07-27-2006 12:17 PM
