Old 12-30-2010, 09:12 PM
ngwanhoe is on a distinguished road
Vertex 4'' Rotary Table hard to turn
Hi I have just bought a Vertex 4'' Rotary Table.
Chronos Ltd Vertex Rotary Tables and Accessories
The handle to turn the table is very stiff. Anyone can advice?
Old 12-31-2010, 12:23 AM
Bump
Old 12-31-2010, 12:24 AM
bump
Old 12-31-2010, 11:56 AM
EPTech's Avatar
EPTech is on a distinguished road
I do not know how much experience you have with indexing tables but here is my idea. The smaller handle behind the scale serves to connect/disconnect the handle (worm)to/from the gear inside. Do not pull the worm too tight against the gear. Leave the slightest bit of play. You may need to loosen the black nut on the front which locks the lever mechanism in place.
Secondly, there are two thumb screws on the front which serve to lock the table. I strongly advice to tighten them during machining after each indexing step.
Hope this helps.
Old 01-02-2011, 06:40 PM
Thanks EPTech.
You mean, take off the handle wheel / hand crank. Inside a black ring holding the worm rod should be loosen and adjust?
Should I adjust the bottom of the table which have a black metal that looks like wedge for the gears?
Old 01-02-2011, 06:43 PM
Thanks EPTECH,
Do you mean take off the crank handle / hand wheel, inside had a black retaining ring which holds the worm drive should be loosen a bit?
Should I loosen the bottom of the table which had a plate that looks like wedge for the gears?
Old 01-03-2011, 10:14 PM
Has completely take the table apart, clean all greese, lubricate with high grade machine oil, assemble and adjust.
Now everthings is smooth...
Vertex Dividing Head BS-0 Manual & Oil Trewella Benchtop Machines 3 10-01-2011 08:45 AM
stepper hard to turn = normal? forgetcolor Stepper Motors and Drives 10 11-30-2010 09:01 PM
Need Help!- rotary table job carlos1970 Mastercam 2 03-06-2009 09:26 AM
Rotary table Piobaire HURCO 0 08-22-2007 07:30 AM
Rotary Table Req h_2_o General Metal Working Machines 9 02-08-2005 01:11 PM
