Old 12-27-2010, 08:09 PM
k24z3 is on a distinguished road
Need help to pick a CNC machine for aluminum
I need a CNC machine to make molds for injection molding and Vacuum form from Aluminum. I see there are many DIY CNC routers out there but they seem to be reliable for woodworking not aluminum. The mold making companies are charging an arm and leg for a mold. Therefore, I am here seeking your expertise.
here are my requirements :
my budget is $10,000
I need a CNC machine to mill aluminum to make molds
The size I need for the X,Y and Z are 1500 x 1500 x 150mm
I dont really need the high speed production of the commercial machine, I just need to have the job done.
Please, the experts in aluminum, point me into the right direction, whether I should put together the machine or to buy one that meets my requirements ?
If you recommend me to build, please recommend me the plans.
If you recommend me to buy, please recommend me the machine(s).
I would really appreciated your help.
Thank You
Router using old PCB pick & place machine celephicus Open Source CNC Machine Designs 2 12-09-2010 10:02 PM
Need A Quote- machine parts for novel PCB pick-and-place device bootstrap Employment Opportunity 0 08-01-2010 03:15 AM
Idler and Drive rollers for pick and place machine p1drobert Linear and Rotary Motion 10 02-07-2010 05:39 PM
pick & place machine gombault LinuxCNC (formerly EMC2) 6 09-19-2009 01:19 AM
Which plasma machine do I pick? HMD CNC Plasma and Waterjet Machines 4 10-10-2007 02:35 PM
