Old 12-21-2010, 07:42 PM
pbukovca is on a distinguished road
need advice
couple nights ago I was parting 0.7 inch diameter solid bar
hot rolled steel around 350 rpm chuck rotating speed
I was cutting small washer and mind you I'm new to metal work.
basically when I got to almost finishing cutting the groove
the machine stopped and after couple of seconds
I hit the emergency stop button. Now I'm not sure
but I think I hear this funny hissing sound from the motor
and I'm not sure it made that noise before.
Does this mean the motor is damaged. Is the motor
damaged if the lathe stops during making a cut??
Thanks in advance for the help.
Pete
Old 12-22-2010, 07:20 PM
packrat is on a distinguished road
Not listing the type or brand of lathe makes it hard to help. Is the headstock belt driven? Maybe you partially broke/split the belt?
Old 12-22-2010, 08:12 PM
its a craftex
Buy the Craftex Metal Lathe 18`x 24in from Busy Bee Tools
LATHE METAL 10IN. X 18IN. 3/4 HP CRAFTEX
RRP:
Price:
$1,299.00 $1,099.00
(excluding tax)
Model:
B2227L
Vendor:
Brand:
Craftex
Condition:
Weight:
170.00 KGS
Rating:
Product Description
10" x 18" Gear Head Machine Lathe
A slightly larger gear head lathe for the serious hobbyist or the maintenance
man who needs a small lathe for specialty repairs. Solid cast iron
construction and a 6 speed gear head spindle gives durability and dependable
service.
Features
Motor: 3/4 HP, 110V, 8.8 Amps
Reversing Switch
Twin Belt Drives to 6 Speed (115 - 1626) RPM Gearbox
18" Between Centers
Swing Over Bed: 10"
Swing Over Cross Slide: 5"
1" Spindle Bore
MT4 Spindle Taper
Number of Inch Threads: 20
Inch Thread: 8-56 TPI
Number of Metric Threads: 9
Metric Thread: 0.5 - 3.0 mm
Lead Screw: 7 TPI
Longitudinal Feed: 0.0025 - 0.005
Tail Stock: MT2 2" Travel 1-1/4" Offset
Cross Slide: 4-1/2" Travel
Maximum Tool Size: 9/16"
Compound: 1" Travel
Max. Longitudinal Travel of Tool Slide - 2.75"
Max. Travel of Tail Stock Sleeve - 2.75"
Gross Weight: 170kg
Carton Size: 47" x 22" x 20"
Need Help!- advice stevieboy OneCNC 2 05-21-2010 09:01 PM
General advice and equipment advice GeorgiaRaised85 General Metal Working Machines 6 03-28-2010 05:00 AM
new need advice kenent1 Benchtop Machines 2 02-21-2008 06:14 AM
New and in need of some advice... well alot of advice! GoonShoes Bridgeport and Hardinge Mills 9 05-30-2007 07:03 AM
Need advice/help studysession DIY-CNC Router Table Machines 1 05-05-2007 04:40 PM
