Old 12-18-2010, 09:59 PM
fayysl is on a distinguished road
Draw comparison between CNC and conventional lathe amd milling machines
I am preparing feasibility study to buy/use CNC machines and want to prove that CNC machines are much better than conventional machines. is there anyone who have the data of parts machined previously on conventional machines and now being machined on CNC machines.
Old 12-19-2010, 06:21 AM
Algirdas's Avatar
Algirdas is on a distinguished road
that's cool. nothing to say.
Can you mark in your study, that on CNC is easy to produce some parts, what is totally imposible by manual?
Next - repeatability of dimensions and accuracy.
Old 12-19-2010, 09:57 AM
It is not easy to come up with a simple answer to 'prove' that CNC is faster. I did the transition from manual machines to CNC in my business starting just over ten years ago and I know that CNC is much more productive per employee, but I don't have the data to directly compare the two. You can read these threads where I describe some of the advantages of CNC. Definitely a big advantage is that you can machine shapes that are difficult if not impossible to do on manual machines as Algirdas mentions.
But it is not just switching to CNC that provides the best improvement in productivity it is also designing fixtures, programs and work procedure to utilize the CNC machine effectively. This aspect is mentioned in my threads.
http://www.cnczone.com/forums/haas_m...y_my_shop.html
http://www.cnczone.com/forums/haas_m...fixturing.html
http://www.cnczone.com/forums/work_f...fixturing.html
If you have any specific questions I may be able to answer them.
Old 12-19-2010, 02:47 PM
The parts to be machined can have a great effect on the type of machines employed to produce them. There is little advantage to a CNC lathe when making long, straight cuts as in roll turning, or long boring cuts.
CNC lathes can become very advantages when the work is more complicated.
Comes back to the old "workpieces to be machined determine the machine to do it".
Dick Z
DZASTR
Clarke CL430 and CL500 lathe and milling machines, any good? billlaws General Metal Working Machines 0 02-28-2010 04:08 PM
New Machine Build- CNC milling&lathe machines and accessories jinandexiaoyan General Metal Working Machines 0 12-11-2009 11:41 PM
New Machine Build- CNC milling&lathe machines and accessories jinandexiaoyan General Metal Working Machines 0 12-11-2009 09:44 PM
New Machine Build- CNC milling&lathe machines and accessories jinandexiaoyan General Metalwork Discussion 0 12-02-2009 01:33 AM
static converter work with conventional non CNC machines chetk43 Phase Converters and VFD 1 02-17-2008 04:20 PM
