Old 12-14-2010, 12:28 PM
samtc is on a distinguished road
Question makino le blode nc64
Does any body knows the parameter to offset the spindle?
This is a makino le blode NC64. When I do a tool change the spindle does not get lock in the proper location, I also have the problem that the screen goes small (all the letters are put into 3 lines on the screen) Can anybody help me
thank you.
Old 12-15-2010, 07:45 AM
emader is on a distinguished road
EMR - CNC Services
What model Fanuc control do you have on machine?
And... is the spindle amplifier a Fuji DSR compact?
You can call me at 859-491-0200 for assistance.
Old 12-20-2010, 02:51 AM
Question
thank you, for your reply. I found the parameter to be 4077. The machine is a Graphite Center snc 64 the tool changer is working now, I was cutting some electrodes when while running the alarm (414 servo alarm Z th axis detection related error) came up. I don't know what it is. do you have an idea?
I think it has a funuc 161
thank you.
Old 12-20-2010, 07:58 AM
414 axis detect
This alarm has to do with position feedback. either a bad encoder, bad encoder cable or excessive reversal error (backlash) in the axis indicated.
If it happens immediately, then probably encoder or cable; if when reversing, look at backlash.
On the road today, so call 859-491-0200 for trouble shooting help.
Need Help!- Makino E33 Tim1 Vertical Mill, Lathe Project Log 0 06-18-2009 11:06 AM
Makino A66 emexcee380 General Metal Working Machines 0 02-02-2009 06:06 PM
Need Help!- makino mc 86 rathi_vk General Metalwork Discussion 0 02-01-2009 09:41 AM
Need Help!- Need Makino Mc-65 or 86 nemco Want To Buy...Need help! 0 11-09-2008 03:05 PM
HELP!!!!! Need Makino J88 Bluesman Employment Opportunity 2 10-30-2007 07:47 AM
