Old 12-13-2010, 11:57 AM
rk396 is on a distinguished road
Mill Recomendation
Ive been lurking for about 4 years now, and in the process have managed to put together a (CNC) plasma table, Router, and a lathe so I've been extremely grateful to all the info I've been able to get from the contributors here.
I'm finally in a position to purchase an actual mill, so my question is what are the real working limits on the X3 (g0704) style mills? I plan on doing everything from Al, carbon steel, and some stainless. Are the X3 style mills rigid enough?
I suppose you can use any mill to cut anything if the cuts are light enough, but i'm looking for practical experiences from people.
I've done a number of searches but never really found an answer to this, so if it's a repeat question then i apologize.
thanks
RK396
Old 12-15-2010, 11:07 PM
arizonavideo's Avatar
arizonavideo is on a distinguished road
The X3 and the Weiss 30 are in the same class with the 30 being slightly heavier and the supper X3 has a better AC motor.
I have not run a X3 only looked around a bit and picked the Weiss 30. The Weiss has a lot larger travels and is a good machine all around with only a few bugs like a sloppy Z gib strip on some machines.
You might take a look at the PM 30 to compare it to the X3.
PM-MV Milling Machines
I think everyone is out of the 20 size machines and the last lot had many bad motors anyhow.
My 30LV has been a good machine so far and I had it about a year.
Old 01-03-2011, 11:33 AM
Thanks for the reply,
What kind of materials are you milling with that class of machine?
Recomendation wanted for a small industrial CNC mill creep_pea General Metal Working Machines 5 09-04-2009 07:16 PM
VFD recomendation Danno Phase Converters and VFD 9 11-17-2008 11:07 AM
Tool Recomendation kbfrazier Haas Mills 7 09-15-2007 01:18 PM
CPR PPR recomendation wcarrothers DIY-CNC Router Table Machines 2 08-31-2006 03:04 PM
EDM Recomendation Tim J CNCzone Club House 0 10-26-2004 06:16 PM
