Old 12-12-2010, 01:44 PM
nicko17 is on a distinguished road
Using linear rails
Has anyone made a cnc with linear rails.
Mainly looking to see if anyone made one strong enough to mill steels.
Old 12-12-2010, 09:23 PM
will gilmore is on a distinguished road
many many builds in the forum with linear rails
Old 12-13-2010, 05:15 PM
I was looking at the linear rails like these
I know there are different style. Are these rigid enough , even when using 2 rails + 4 blocks per axis.
I'm worried they are going to have alot of slop in them.
Old 12-13-2010, 05:55 PM
That style was used in the past by many builders. They are usable for light duty machines, but not very good for heavier more accurate machines.
The more demanding machines use ball or roller profiled linear guide ways and matching bearing blocks.
Dick Z
DZASTR
Old 12-13-2010, 07:23 PM
Alright thanks.
What do most ppl use for support under them. I know you need to have a ground flat surface if you want accuracy. But since i dont have access to a surface grinder big enough , nor do i think 95% of us do. What would be another option ... milling ... some kind of flat stock.
Old 12-14-2010, 07:44 AM
Depending on accuracy required, you could mill flat surfaces to mount the rails to.
This can also provide a small shoulder to locate a rail against as most manufacturers suggest. Just keep the shoulder low enough to clear the underside of the linear bearing block.
Dick Z
DZASTR
Old 12-14-2010, 07:52 AM
How about finding a surplus steel or granite surface plate? Probably flat enough and a bunch of mass to boot.
Old 12-14-2010, 06:44 PM
That would be almost perfect (cant exactly drill holes in it to mount) I think only option would be epoxy stuff i was hearing about.
Old 12-14-2010, 07:57 PM
or through drill and bolt
Old 12-14-2010, 08:26 PM
What about all those aluminum rails i see people using. I cant seem to find the exact name of them.
  #11   Ban this user!
Old 12-14-2010, 08:37 PM
80/20® Inc. - The Industrial Erector Set�
  #12   Ban this user!
Old 12-15-2010, 09:40 AM
In post #1 you wanted to mill steel. I would not use "erector set" aluminum construction for milling steel unless you are performing "ultra-light" machining.
Dick Z
DZASTR
Parker Linear Motor - IKO 35 series 69" linear Rails S.A.C. EBAY ADS 1 07-28-2010 08:33 AM
Thomson Bars, V-Rails, or Linear Rails Chuck_M Linear and Rotary Motion 9 12-18-2009 02:39 AM
Newbie- linear rods versus linear rails haylspa Benchtop Machines 4 08-11-2009 08:44 PM
Linear Rails kylemp Want To Buy...Need help! 3 07-05-2009 03:44 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
