Old 12-10-2010, 11:34 PM
jmharrel is on a distinguished road
print vs solid
What trumps what? A print or a solid file? ive found that solids dont allways match the prints. please help.
Old 12-11-2010, 03:42 AM
Algirdas's Avatar
Algirdas is on a distinguished road
do as follows:
1. print your solid file.
2. scan and convert your print to solid.
You got two different prints and two different solid files.
Ask the question from the start.
Old 12-11-2010, 09:00 AM
Andre' B is on a distinguished road
If you are doing CAM work off the solid and find that the drawing is not the same.
Get the customer to sign off on what they want before making any chips.
Old 12-13-2010, 02:44 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Print does.
A solid does not specify material, surface finishes, tolerances, datums, etc.
If you don't send a supplier a proper print, don't expect a proper part.
www.integratedmechanical.ca
Old 12-13-2010, 03:15 PM
mcphill is on a distinguished road
3D surfaces are impossible to represent in a print. We make prints that define the critical areas of the part, but the model "rules" in all other dimensions. If you have a model that does not match the print, then something is wrong and the customer must fix the incongruence.
cant print? erase42 BobCad-Cam 13 11-30-2009 08:05 AM
Print Variabledata cncboy1 Okuma 11 11-23-2009 04:46 PM
Need Help!- Is there a way to have BC print out a Blue Print of a drawling? Stampede BobCad-Cam 3 01-05-2009 07:36 AM
RFQ Create Solid Model from Part Print Jim Estes Employment Opportunity 0 06-15-2007 01:22 PM
Which came first, Solid Edge or Solid Works? Arnie General CAM Discussion 3 09-15-2004 06:25 AM
