Old 12-08-2010, 12:09 PM
jphodson is on a distinguished road
Cool Okuma LT300MYW sub-part ejector
Has anyone seen or know about some sort of comfirmation device for the part ejector used in cnc lathes particularly an Okuma LT300 w/P200 control?
Something that will throw an alarm/slide hold.
FYI, my first post so excuse any screwups.
Old 12-08-2010, 01:42 PM
Algirdas's Avatar
Algirdas is on a distinguished road
what's the problem at first?
Old 12-08-2010, 01:53 PM
Occasionlly a part will not be ejected from the sub spindle because of a chip buildup or whatever then the sub (W-axis) will advance to main spindle to grab the next part and there's an undesirable meeting of the two.
Old 12-09-2010, 03:13 AM
Algirdas's Avatar
You can make sensor on the bucket. maybe combination of two: one sensor is actuated - just button pressed by some tool (according part program) and timer starts. Timer causes error if no reset from second sensor, dropping part.
error action - up to you. You can activate slide hold, for instance
two parts could be damaged, sure. You will get an alarm of W overload, it protects the machine only.
There is another, simple solution. Use a tool to side touch not ejected part. No chance to keep it in the sub-chuck (unclamped) while pushing a little with the tool.
The third solution. Sure, you can make confirmation sensor. A pin, pushed by spring towards the part. The pusher must be hollow, you need proper sealing, you need additional electrical input, appropriate software ... bla bla bla ---
Old 12-09-2010, 08:13 AM
Thanks Algirdas, good ideas. I'm going to try taking a tool like the cutoff and using load monitor to sense wheather there's a part there or not. In the mean time work on adding prox switches to the part catcher.
Old 12-09-2010, 01:24 PM
Algirdas's Avatar
load monitor will not sense unclamped part. Make the tool path so, that it will not leave the part in the chuck for sure.
Old 12-09-2010, 01:50 PM
Thanks, looks like it will work.
Ejector pin grinding/cut off machine? Chuck Reamer Moldmaking 19 10-15-2011 05:58 AM
Need Help!- Sub-Spindle Ejector for Tsugami NP-20 Thrasher CNC Swiss Screw Machines 3 04-12-2009 08:30 AM
Need Help!- Okuma Howa 2sp-30H part # OKUMA Tech Okuma 0 11-14-2008 02:19 PM
Ejector question - electric machines dav612 Moldmaking 4 02-15-2008 02:48 PM
Can an ejector pin sit against a shutoff surface. DomB Moldmaking 25 04-13-2007 07:01 AM
