Old 12-04-2010, 11:56 PM
ice_2k4 is on a distinguished road
ice_2k4 Multipurpose machine
Hello everyone, I am working on a new multipurpose machine. The base is 2' by 4' welded steel tubing (3", .25" thick). A .5" thick steel plate is welded to the top of the tubing. I created a frame on this top plate so that I could pour resin on it to provide a good level surface for mounting some linear bearings.
I have some 25mm wide by 762mm long linear bearings that I plan to use temporarily (as they were sourced for a different project). The machine will have a fixed, welded steel gantry. The Y and Z axis will be made from one of these compound tables:
shars.com - Heavy Duty Mill amp Drill Table
I hope for this machine to be able to serve as a surface grinder, as well as a mill/router. So, I purchased a toolpost grinder from LMS:
LittleMachineShop.com - Tool Post Grinder
And now for some pics.
Old 12-07-2010, 05:37 PM
I had some issues with my first try at leveling the surface of my machine with resin. I didn't get everything sealed up properly and got a sink hole in the pour, along with a nice mess in the garage.
For the next try, I used some .5" x .5" angle to build the resin pool and sealed up the outer edges with silicone. When I was breaking the original pour free, I noted that it was pretty easy to chip away which made me a bit concerned with the durability of the resin on steel. With the angle iron, I have small gaps that I hope the epoxy seeped under that will prevent the edges from "lifting" up.
For this pour, I also thinned the resin out a bit more with Acetone. Sadly, the resin I got from home depot had already started to set up (without hardener, so it had rubbery chunks in it). Luckily, I had enough other resin to complete the pour and didn't get too many chunks in the final pour. The chunks caused little dimples on the surface in a couple of places that I will have to sand/scrape level. Overall, I'm very pleased with how the surface came out. When I place the linear rails I have on the surface, I see no gaps between the rails and resin.
Also, I had originally stated I was going to temporarily use some 25mm x 762mm Hiwin linear bearings (Actually they are 30mm), but I ended up biting the bullet and buying a set of Hiwin high precision 30mm x 1190mm rails from Automation-Overstock:
http://www.automation-overstock.com/...0HA2R1190Z3PII
New Machine Build- Sell CNC router ,CNC engraving machine ,CNC laser machine kelvinguo CNC Machining Centers 0 10-07-2010 12:39 AM
cnc router/CO2 laser machine/cnc plasma cutting machine cncengraver Chinese Machines 0 06-25-2010 09:48 PM
Need Help!- Hardinge CBN Turning Machine with GE Fanuc Machine Model CS- 51, S.No. CL – 622 -BSP M.RISHIKESH Hardinge Lathes 1 11-20-2009 06:03 PM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 09:37 PM
