Old 12-02-2010, 04:44 PM
dmimoto is on a distinguished road
BP Interact 412 revival
I'm trying to revive a 1989 BP Interact 412 with Heidenhain TNC 2500B control that has not run in 5 years. When last operated it ran fine.
When started up the manuel says the screen should say "POWER INTERUPTED" which it does. Pressing the CE button then puts it into manuel mode, but the screen does not show the "PASS OVER Z", Y, and X graphic so that I can zero the machine. I have pushed every button trying to get this graphic to come up, but have had no luck.
I know this is an old machine, but I'm hoping that someone out there still remembers how to operate it.
Thanks for any leads anyone might have.
Old 12-04-2010, 07:36 AM
Algirdas's Avatar
Algirdas is on a distinguished road
is it BridgePort?
Old 12-04-2010, 11:04 AM
Yes it is a Bridgeport vertical machine center.
Any ideas ?
Old 12-05-2010, 10:37 AM
Algirdas's Avatar
did you checked all circuit brakers? <- inside of main control cabinet
is backup battery voltage in range?
Old 12-09-2010, 02:01 PM
I have not check those.
Let me check them and I will let you know what I get.
Thank you,
Steve Owen
Old 12-15-2010, 04:52 PM
RMARCH's Avatar
RMARCH is on a distinguished road
I use this machine every day........The batteries probably went dead from sitting for so long.............I would change them and reload your Parameters.
Then see what happens.
Old 12-15-2010, 05:02 PM
Thanks for the input.
The backup batteries were very low, below 3 volts.
Where do I find the correct parameters to reload ?
Thanks again for the help,
Steve Owen
Bandit Revival ? HPbyGD Mentors & Apprentice Locator 6 05-02-2010 08:04 AM
BP Interact 308 Hernthehunter Bridgeport and Hardinge Mills 0 06-21-2009 06:03 PM
Interact 412 besc Bridgeport and Hardinge Mills 0 03-15-2009 05:54 PM
Interact 1 Mk.2 help Kevin77 Bridgeport and Hardinge Mills 8 02-17-2009 08:37 AM
Interact 412 besc Bridgeport and Hardinge Mills 0 08-24-2006 07:52 AM
