Old 12-02-2010, 09:34 AM
notShai is on a distinguished road
chuckless or chuck? Central Machinery Drill Press
hello, i have this Central Machinery Drill Press 5 Speeds. Model S-5901, Capacity 13MM, spindel MT2.
looking at where the drill bit suppose to go i go blank !
it looks like nothing i've ever seen.
dos anyone know what that is?
is it missing a piece?
see attached photos.
thank you
Name:	Copy of DSC03233.JPG‎
ID:	120496   Click image for larger version
Name:	Copy of DSC03234.jpg‎
ID:	120497   Click image for larger version
Name:	Copy of DSC03232.jpg‎
Old 12-02-2010, 10:42 AM
jalessi's Avatar
jalessi is on a distinguished road
notShai,
Do a search on eBay for a "MT2 Chuck"
Make sure it come with the arbor, yours is a MT2 (Morse taper #2)
You can get either a Jacobs chuck or a collet type.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 12-02-2010, 11:07 AM
hi Jeff,
looking at the hole its something like 2mm in diameter (see image 1), i looked up the part you mention and i dont see how it can attach (looks too thick)
are you sure thats whats needed?
see this:
1/2" HEAVY DUTY LATHE DRILL CHUCK MT2 ARBOR w/ key! - eBay (item 360323127895 end time Dec-03-10 17:35:52 PST)
Old 12-02-2010, 11:15 AM
jalessi's Avatar
Post
notShai,
The part you posted in your picture (image1) is just a MT2 arbor.
Jeff...
Old 12-02-2010, 11:16 AM
jsheerin's Avatar
jsheerin is on a distinguished road
You need a drill chuck with the morse taper in the chuck. I read your spec to say that you have an MT2 on the shaft of the drill press. The chuck fits over the taper on the drill press. Like this one (although it has extra adapters you don't need):
1/2" DRILL CHUCK STRAIGHT MT2 MT3 MT4 R8 SHANK ARBORS - eBay (item 330495387374 end time Dec-11-10 06:39:45 PST)
CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
Old 12-02-2010, 11:22 AM
jalessi's Avatar
Post
notShai,
There is a good chance the old chuck was slipping and scared the surface of the existing arbor.
I suggest replacing the existing arbor, that way it will fit the new chuck properly.
Jeff...
Old 01-04-2011, 04:06 PM
darn it !
i bought two and none works HELP
is there a part number or something i can use?
the HOLE in my machine is 2 milimiter wide all those items are too big !
i am about to give up and junk the item at a loss
this is what i bought-
Central Machinery Drill Press, Hobbies, No chuck, 110V - eBay (item 290471093694 end time Nov-22-10 12:45:21 PST)
these are the chucks i bought -
1/4 MINI Snap In Hex Shank KEYLESS Electric DRILL CHUCK - eBay (item 230481670327 end time Jan-25-11 11:26:36 PST)
New 1-13MM B16 Keyless Drill Chuck with MT2 Shank - eBay (item 260510217345 end time Jan-14-11 19:20:04 PST)
Old 01-04-2011, 04:20 PM
neilw20's Avatar
neilw20 is on a distinguished road
The spindle sticking out is tapered? Measure it. The big ones look straight at first glance, unless it is a special.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 01-04-2011, 06:25 PM
packrat is on a distinguished road
When you extend the spindle down is there a slot that goes through th spindle length wise? If not the spindle is NOT a MT(Morse taper) spindle.
The listing in Ebay was wrong. It should have been listed as a JT(Jacobs taper) This and threads are the standard drill chuck mountings. Here is a chart of the different taper dimensions - http://www.jacobschuck.com/pdf/Techn...nformation.pdf
Central Machinery mini Mill nateman_doo Benchtop Machines 2 07-06-2010 03:05 PM
Central machinery mill CNC conversion? wyobmf Benchtop Machines 5 12-21-2006 02:26 AM
supply forging press machinery xindekaishi Product Announcements & Manufacturer News 0 07-29-2006 03:11 AM
Central Machinery Drill Press JavaDog General Metal Working Machines 10 05-25-2005 10:14 AM
