Old 11-30-2010, 01:13 PM
BSawyer486 is on a distinguished road
Help needed
Hey guys,
Sure hoping I can get some help here PLEASE... I'm running a Hitachi Seiki with Seicos control. The other day I was sending a program to the machine and the computer locked up on me. Now when I start the machine I can do anything I need to do as long as I dont try to edit anything. As soon as I hit edit I hear a contactor kick out and the computer locks up. From what I hear there is a procedure to solve this issue but I have no idea what that would be. I have the parameters backed up so I'm ready to try some things. If anyone in the ZONE has had this issue before maybe I can get some help...PLEASE.
Thanks in advance.
Bruce
Old 11-30-2010, 08:16 PM
Really
You mean with as many people there are here in the zone, NO ONE has ever encountered this problem. It seems that if there is a problem with a program so you have to dump all the programs in the control but when you hit edit that's it.
Seicos apparently has a procedure to fix but will not give out that information.
Thanks for any help anyone can give.
Bruce
Old 11-30-2010, 08:49 PM
mechcanoer is on a distinguished road
Lack of help from the manufacturer is why the company I work for sold their Hitachi Seiki.
Old 11-30-2010, 09:51 PM
I can believe it
Old 02-21-2011, 09:31 PM
Let's try this one
Ok guys,
I have burned up my C6 spindle speed control board after nearly two years of almost flawless operation. Bought a C41 board to replace it and as of now I have not been able to get the output at the 0-10vdc terminal. All I can squeeze out is 3.84 volts when I call for max spindle speed. half spindle speed gets me 1.9 and thru the rest of the range it stays linear. I know I am suppose to have nearer 10 vdc max but it aint there. The relays enable with M3 and M4 and disable with M5 like I assume they should. Anyone have any ideas how to get to output voltages up where they ought to be. when I first connected it I was only getting 2.04vdc at max and at half speed 1.0 so IO think I am pretty close. Really would appreciate any help anyone might have to offer.
Thanks,
Bruce
Space needed behind TM-1 needed? helocat Haas Mills 9 05-20-2010 08:31 AM
PVC Help needed MikeUSNRet Vectric 4 04-21-2010 02:04 PM
Need Help!- M-32B help needed please. Txshane Mazak, Mitsubishi, Mazatrol 2 03-06-2009 04:49 PM
Just IN- help needed Korte Want To Buy...Need help! 1 03-07-2008 04:27 PM
Newbie- HELP NEEDED R.O.M.O.A.S Want To Buy...Need help! 0 03-03-2008 10:56 PM
