Old 11-28-2010, 12:38 PM
RP Designs is on a distinguished road
to retrofit or not?
I have a Smithy Mill lathe combo which i purchased as my first machine tool. Honestly I havent used it much because I found it very limited for any sort of real work. If anything I have used the lathe the most and I still use it although I would like a larger lathe. I have a full size CNC knee mill that I use for mill work so I dont ever use that part of it. I was thinking about doing an inexpensive stepper retrofit to make it a little more hands free, but it seems like I should use a servo for the chuck to coordinate the chuck position. Obviously there is very diminishing returns with this machine, so I don't want to spend a lot but I have the machine, some tooling and the space. The question is should I?
I was thinking mach3, with gecko drives & steppers on the longitudinal and cross slides, and a servo on the rotary axis for speed and positioning.
Has anyone done this? Thoughts, comments, words of caution?
Old 11-28-2010, 03:02 PM
Torsten's Avatar
Torsten is on a distinguished road
Retrofitting a Machine dose not change the kind of Parts you make on it.
I would think if you dont like the machine there is little point to invest further into it.
But one thing seams like a obvious answer, why dont you use the small Machine to make Parts to retrofit your larger Knee Mill.
The increase in cost would be small and this Machine would be much more usefull to you.
After your done just sell the Smithy and recover some of your cost.
Good Luck
Old 11-28-2010, 04:10 PM
Good Luck
Actually the larger knee mill has already had the retrofit done. The benefit to me retorfitting the lathe would be for the more tedious tasks such as turning down larger diameters where it is basically a lot of nibbling away. I would like to be able to turn the machine and walk away to do other tasks while the tedious stuff is being done by the machine.
Old 11-29-2010, 09:23 PM
Ed from NY is on a distinguished road
I'm not sure what others think, but one possible criteria is: If the base machine value isn't twice as much as what you plan to spend in the conversion then it is a pass, that is, sell the base machine and start off with a higher model.
Millpwr Retrofit-Retrofit on Bridgeport pofo Bridgeport and Hardinge Mills 5 03-07-2010 05:19 PM
2-UVR-C Retrofit yoopertool Tree 10 12-30-2009 10:44 PM
To retrofit or buy new? RP Designs General Metal Working Machines 9 03-04-2009 12:17 AM
Newbie- Sieg X1 retrofit with Linux EMC2, CNC Fusion retrofit kit and Gecko G540 GreenLead Benchtop Machines 31 11-26-2008 11:55 PM
Need Help!- camsoft retrofit to a anilam crusader retrofit bowlingmac CamSoft Products 44 07-24-2008 09:00 PM
