Old 11-25-2010, 10:31 PM
Shooter7 is on a distinguished road
Gib Adjustment Question...
On my Lagun FTV-4, I was adjusting the X axis and Y axis gibs....and think I may have diagnosed an issue.
I bought the mill used about 6 months ago...and have not had time to work on it till lately. I did have it torn down and reconditioned back to new tolerances. After the work was done...I inspected it using a 16" AA granite square. All axis were square to .0002-.0003" per foot. I double checked at multiple points in on the non tested axis (ie...I tested the perpendicularity of X and Y at multiple Z points.) Overall I was very happy with the reconditioning...or so I thought....
Today was cleaning things up, and adjusting gibs. I started with the table (X-axis to saddle) adjustment. I locked the saddle down to the knee, and the knee to the column. I mounted a 50 millionths indicator on the table...and ran the stylus to the saddle body. I then adjusted gib by feel, while also trying to twist the table on the saddle by pushing first on one end of the table...then on the other..and seeing if I could get the table to pivot on the saddle. I got the table to where the most I could get the indicator to move was about .0001"-.0015"...and the table was not too tight to move by hand. So far so good.
The saddle to knee connection looks like more of a problem. I locked down the table to saddle...and unlocked the saddle to knee. Went through the same steps...but no matter what I do...when I push on one end of the the table...then the other, there is relative angular twisting of the saddle relative to the knee. Even if I tighten the gib to the point that it is definitely too tight, there is still angular pivotoing. I am picking up about .0015" of motion..from the saddle to the knee. If I set the indicator on a separate stand from the mill...and set the stylus on the table...I can move it .005" total at the end of the table. About .002" is just flexing...but .003" is slop...
I think the root cause of this relates to the fact that this mill has a power knee set up, and the Y-axis lead screw is offset to the left. This means that whenever you move the saddle on the knee, there is a moment that acts on the saddle to knee way contact are. This will cause the saddle to wear on the ends of contact...and the gib to wear on the ends....
I paid good money to get this done right...and it does not seem right. No way the table should slop around like that...
Here is what I would propose to do to start to check things out...
1. Order some .438-.500 precision ground pins
2. Pull the table and saddle off.
3. With the pins set into the dovetails on the knee...some gauge blocks....and a mic...measure the parallelism knee way. Should be within .0002: end to end.
4. I do trust that the flats are good. There was some wear there before the recondition I had done...and that was repaired. The out of square associated with that wear was also eliminated...so the horizontal flat to flats should be OK.
5. I could perhaps take the saddle into someone who has a prismatic master of the same angle...and have them check the angled female dovetail for flatness....
6. Spot the dovetails...carefully replace the saddle...hammer in the Gib...and see how the fits look.
If either 5 or 6 are off...then I guess I need to go back to the guy I had rebuild it...and demand some correct. My worry is that is has been so long...I may not get a lot of support...
Any other advice on how to diagnose this issue?
Thanks in advance,
BW
Cross slide motor/belt adjustment question BrassBuilder Vertical Mill, Lathe Project Log 0 07-05-2010 06:29 PM
BMC-20 Box Way Gib Adjustment fasto HURCO 4 03-22-2010 03:35 AM
Need Help!- DV-59 Gib Adjustment HBFixedGear Hardinge Lathes 1 04-20-2009 10:02 PM
Way adjustment on TM1 f1jdm Haas Mills 8 12-01-2008 12:50 PM
QC Nut adjustment zcases Bridgeport and Hardinge Mills 3 06-10-2007 09:10 PM
