Old 11-25-2010, 05:36 PM
trav is on a distinguished road
Weld vs screw/bolt
Curious to know what peoples thoughts are on the benifits / reasons not to weld vs screw/bolt a structure like this together?
T'would be the z-axis on a moving gantry machine. Bottom plate would be bolt on to make it removable but the rest?
Cheers,
Trav
New Machine Build- No-Weld Steel 1 x 0.5 x 0.2m Benonymous DIY-CNC Router Table Machines 49 05-16-2012 02:44 AM
Weld Beads zooloader Solidworks 6 08-26-2007 04:59 PM
Weld vs braze pminmo Welding, Brazing, Soldering, Sealing 13 11-09-2005 03:22 AM
Weld specs zcases Welding, Brazing, Soldering, Sealing 1 10-17-2005 08:58 PM
Do I weld or glue? andy_ck87028 Mechanical Calculations/Engineering Design 8 10-08-2005 06:10 PM
