Old 11-20-2010, 04:45 PM
webgeek is on a distinguished road
Aluminum Cutting NIGHTMARE!
I know Halloween was a month ago but you'd think it was this afternoon in my garage. I've finally got around to hooking up my flood coolant and setting up vises, a tooling plate, etc. So I got all this set up and try to cut. It comes out so bad it's embarasing. Here are the specs...
12" x 24" .09" 6061-T6 aluminum sheet from Speedy Metals
Speedy Metals - .090" 6061-T6 Aluminum Sheet
0.25" 4-flute HSS endmill - brand new
.025" depth of cut
25 IPM
SynKool coolant
And here is a video showing the monstrosity:
YouTube - Beaver Nibbling Some 6061 Aluminum
Any suggestions? I've never cut the plate before, always just small flat stock and I've never had anything gum up this bad. I tried this same metal with a BRAND NEW .25" 3-flute Maritool carbide bit, a lightly used 2-flute .25" end mill as well. I also tried from as slow as 20 IPM (MUCH WORSE) and up to ~35 IPM (no visible improvement).
Thanks in advance for the help!
-Mike
Old 11-20-2010, 05:26 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
heat
looks like a melt down problem caused by plunging a 4 flute
its clear when the tool rises in the z that there is aluminum stuck to the tool , best bet is to ramp in and use a 2 or 3 flute
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 11-20-2010, 05:35 PM
MrWild is on a distinguished road
What Derstap said. 4 flute sucks for aluminum, but it also seems like that isn't 6061. Acting gumming like 50 series.
Old 11-20-2010, 06:01 PM
Thanks for the quick replies!
The tool isn't plunging, it's actually ramping in along the cut path (a cool feature of Visual Cam). I've attached a screenshot of the cut level setup for that part. I might be misinterpreting the settings for this screen so please check it out. The "burning" of the bit occurred in a blink of an eye as it started ramping in even with coolant washing over it.
You guys mentioned this is a problem with 4-flute bits but I tried with both a dirt cheap Enco 2-flute bit and a nice carbide 3-flute endmill specifically designed for aluminum from Maritool and in all cases the behavior was the same. Ironically, the 2-flute junkie bit easily out-performed the expensive carbide bit. All of the results were terrible though.
Should i be using the carbide and running LOTS faster? I just can't seem to get this aluminum to cut. It's labeled 6061 right on the sheet but this cuts far worse than anything I've run into so I assumed it was me. Can there be something wrong with the metal?
-Mike
Old 11-20-2010, 06:09 PM
foam27 is on a distinguished road
Quality carbide 2 fl, lower spindle speed, higher feed rate, go less on the depth of cut.
If all else fails, start at .005" DOC and increase DOC until quality degrades, then back off a bit.
my 2 cents.
Old 11-20-2010, 06:17 PM
It may be a low temper. 6061 is an alloy that is normally age hardened, it is done at a moderate temperature for a few hours. In the tempered form, normlly something like T655 it is very difficult to bend so sheet and plate stock is available un-tempered (T0) for applications that require bending.
T0 is horrible to machine beause it gums up the cutter. Definitely use a two flute cutter at a very high rpm. You could run a 1/4" cutter at 20,000rpm with plenty of coolant, a slowish feed such as 0.001" per tooth and it should machine okay.
Old 11-20-2010, 06:47 PM
woffler is on a distinguished road
I agree, i cut 6061 all day long i use a three flute end mill 3/16 coated i use a small depth of cut .05 ,9500rpm spindle speed 29 to 30 inch per min feed. and cut through 5/8 material with more corners and angles and several radius's there is something wrong with the material as suggested by Geof there is no way your cutting tru 6061 from what i saw in the clip.I have had a material mix up from suppliers before that has been mis marked at factory try a different supplier for a known source .
Old 11-20-2010, 07:09 PM
I ran your feeds and speeds threw the calculator i use that has a lot of variables figured into it and this is what i came up with, 6000 rpm ,depth of cut .025, width of cut .25, feed rate should be 28.8 inch per min. ,plunge rate 14.4 per minute ,tool deflection .0003 using a 2flute high speed steel end mill should give a good cut with no chatter.
Old 11-21-2010, 06:41 AM
1%biker is on a distinguished road
Hi there
I rout aluminum daily on a multi-cam 5000 series machine. I have found single flute Onsrud cutters the most superior cutters I have ever used. I would recomend using single flute cutters combined with Boelube coolant on modern routing machines. On soft alloys I use High spindle speed and a slow feed rate combined with mist coolant (Boelube liquid). My best results for 6061 use Spindle speed of 21000 rpm feed at 39.37 ipm. Soft alloys are always difficult to machine cleanly. What ever cutters you use I would suggest using the cutter manufacturers feeds and speeds reduced by 1/3. this generally works for me. Depending on machine, work holding, coolant and cutter you will only achieve good results by trial and error. Hope that is helpful.
Jim
Old 11-21-2010, 08:14 AM
Don-in-Japan is on a distinguished road
I only use SpeedyMetals 6061 flats on my little A2Z cnc machine.
25 IPM at around .020" 2800RPM dry cuts with plenty of plunges, and have no problems. (I only use the discount 9/64" 2 flute HSS end mills from Victor machinery).
My many failures at machining aluminum tell me it doesn't machine at all like 6061, and may be mislabeled. It screams too soft.
My 2 yens' worth.
  #11   Ban this user!
Old 11-21-2010, 08:27 AM
fizzissist's Avatar
fizzissist is on a distinguished road
I cut 6061 T6 all the time, and your video makes it look like the material isn't in a T6 condition or the cutter has flank wear. Surface scale??
The Dataflute carbide endmills have given me awesome performance (I'm not a rep, just a happy customer), so I'd recommend their 2 flute stub ARF style in a C5...
ARF-ST-20250-32857
http://www.dataflute.com/catalogs/da...atalog2006.pdf
You should be able to run it at over 800SFM, .002 feed/tooth, all day long...12,000rpm, 48ipm
One BIG caveat....get that coolant focused and right on the cutting channel, so you get those chips outta there! Looks like you're hand-holding it. Make a clamp so it's consistent.
If the material is ringing, as thin stuff is prone to do, consider a heavy ring if you can that will sit outside the cutting zone that will weight down and dampen the sheet, and give you something extra to clamp onto.
......One other thing....Change that ramp angle down to 3 degrees! 10 is too steep.
When you're done, do another video!
  #12   Ban this user!
Old 11-22-2010, 08:47 AM
Cruiser is on a distinguished road
The four flute is the root of your evil ! The 4flt doen not have enough room within the flute chanel to carry the chips from the heavy feed rate. they curl up and fill the channel then rub and melt. As the others are saying drop to a 2 or 3 flt designed for alum and you will see the bigger open area for the chips to flow in.
Don
IH v-3 early model owner
Cutting Aluminum On X1 CNC DFason Benchtop Machines 4 08-16-2010 03:43 PM
Cutting Aluminum bossfrog DynaTorch 8 07-07-2008 09:21 AM
Need Help!- Cutting Aluminum jeffmorris General Metalwork Discussion 3 02-27-2008 04:14 PM
Cutting aluminum rocks101 DIY-CNC Router Table Machines 5 02-27-2005 01:29 PM
Aluminum Cutting Tazzer DIY-CNC Router Table Machines 5 07-29-2003 12:09 AM
