Old 11-19-2010, 12:16 PM
frontrange is on a distinguished road
Anyone able to do metric threading want a small project?
First, forgive me if this is the wrong forum for this. I'm working on converting a Logan 12X36 lathe to CNC and I've got a small problem. I got a very sweet deal on a really nice ground ball screw for my z axis. I was able to get it properly sized on the floating end after spending a whole day going at it with a tool post grinder. Today I'm going to assemble it and discover my fixed end nut won't screw on past the first thread or two. Turns out they threaded the M20 end of the screw at a .8mm pitch instead of a standard 1mm.
So anyone able to turn me a new nut for a reasonable fee? Or if anyone has an idea where I might source one I really would appreciate it.
TIA/Steve
Old 11-19-2010, 12:40 PM
juergenwt is on a distinguished road
Frontrange - There is no M20 x 0.8
Most likely you have M20 x 0.75
Check again.
Check with "Maryland Metrics" for a Nut or a tap.
Old 11-19-2010, 01:12 PM
Nope, it really is M20x.8. With surplus ball screws you get what you get.
Old 11-19-2010, 01:27 PM
nusolar is on a distinguished road
nuts
Have you tried to contact the company who made the ball screw ?
I could make a nut for you if you can't locate one,let me know
Old 11-19-2010, 01:35 PM
Afraid there's no way to identify the source of the ball screw. All I know is it's hardened all the way through (good thing I have a toolpost grinder, carbide wouldn't touch it) and preloaded with a double nut. I'm sure someone paid a bunch to have it made.
If you could just turn an internal M20x.8 for about 1/2 inch or so on a piece of scrap I can do the rest. Metric threading is the biggest reason I'm doing CNC on this lathe. Everytime I run into a metric issue it is a showstopper for me.
Please let me know how much and if PayPal is ok. And thanks a bunch!
Old 11-19-2010, 02:19 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Can your lathe do 32tpi?
0.8mm pitch is 0.0314". 1/32" is 0.03125".
If you turn a 20mm x 32tpi thread your theoretical lead error is only 0.00015" per thread. Sounds close enough for me.
I could turn a 0.8mm pitch thread, but have no reference gauge to determine when the thread is done. The chances of my thread being any more accurate than you turning a 32 tpi thread and trying it out on the screw it needs to fit is slim.
Regards,
Mark
www.wrathall.com
Old 11-19-2010, 02:37 PM
I have about 12" of ball screw I cut off, including a sample thread. But your point is a good one, 32TPI may be close enough. I'll give it a try and see how it fits!
Old 11-19-2010, 02:58 PM
turnning and threading is no problem for i have CNC's I would use, but as posted before gaging and or checking is a concern.does your manual lathe have metric gears ?
Old 11-19-2010, 05:11 PM
No, Logan metric interposing gears are insanely expensive, money better spent on CNC conversion which is what lead me here in the first place. I did cut a sample 32TPI and checked it with a thread gage - looks close enough.
Small/Metric endmills Magnum164 Tormach PCNC 12 10-20-2010 03:43 PM
Need Help!- Threading Metric Threads on Mazak T32 fiat4726 Mazak, Mitsubishi, Mazatrol 3 05-08-2010 04:08 PM
Need small indexable threading bar Crashmaster General Metalwork Discussion 9 04-09-2009 08:13 AM
Problem- Threading Standard/Metric Bill308 General Metalwork Discussion 6 02-06-2009 05:22 PM
Need Help!- Metric Threading jroma1 Mini Lathe 1 04-17-2008 09:12 PM
