Old 11-18-2010, 05:34 PM
metricmike is on a distinguished road
Gecko 540 + Keling Power Supply + Keling Steppers - Good combo?
Im looking at purchasing a gecko 540 controller, Keling Power Supply KL-600-48 48V/12.5A, and 4 Keling KL23H284-35-4B Steppers.
Would this make a good combination? Is that an appropriate size power supply for both the controller and steppers?
I will be using this for a cnc table that will both do plasma and aluminum milling.
Old 11-18-2010, 06:01 PM
will gilmore is on a distinguished road
the 381s have the low inductance that is supposed to be a good match for the g540 plus 387s are out of stock
Old 11-19-2010, 02:37 AM
Okay, thanks. After some reading/learning about inductance, those seem like a good idea.
Can I get away with the smaller/cheaper 48v 7.3a running 4 steppers? 2 of them will be for dual driving the gantry. Any other power supply suggestions?
Old 11-19-2010, 02:53 AM
hoss2006's Avatar
hoss2006 is on a distinguished road
Probably could, the formula (from gecko) for gaging a power supply is to add all motor current
then multiply by .6.
(4)3.5 x .6 = 8.4 Amps.
If you don't run 3D parts and only 2 axis move at the same time, you'd be under.
I've run (3) 5 Amps motors simultaneously on the same 7.3A supply no trouble.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Need Help!- Keling power supply judleroy General Electronics Discussion 4 04-18-2010 10:36 PM
Keling Power supply judleroy General Electronics Discussion 11 08-25-2009 12:08 AM
Gecko 540 Package from Keling. Good Choice or Not???? JeLC DIY-CNC Router Table Machines 1 03-02-2009 06:20 PM
Need Help!- Gecko 540 Mach 3 Keling Steppers on a Taig gunlocators Gecko Drives 4 02-21-2009 02:58 AM
Keling power supply? mcruff Automation Technology Products 5 09-23-2007 09:11 PM
