Old 11-04-2010, 11:01 AM
turbo2ltr is on a distinguished road
Vactra 2 for Vactra 1?
The manual for my machine (Acromax MX16 from 1984) recommends "Vactra No 1 or equivalent".
I can't seem to find Vactra 1 in anything less than 5 gallon bucket. I really don't want to spend that much seeing as the lube that was in the 1.5 quart reservoir has lasted me almost a year. I don't use the machine that much. I see Vactra 2 is available in 1 gallon containers. If I'm reading this right, it would seem #1 is 10w and #2 is 30w so that's probably not a good substitute.
Ideas? Suggestions? Place that sells #1 in less than 5gal containers?
Thanks,
Mike
Old 11-04-2010, 12:12 PM
underthetire is on a distinguished road
I would check with some local tooling houses. I know the local one here has small containers available. And yes, Vac 2 is more of a standard.
Old 11-08-2010, 05:18 PM
A lot of very excellent info here:
Mobil Lubricants explained - Research - The Home Shop Machinist & Machinist's Workshop BBS
Seems the old Vactra 1 is now Vacuoline 1405
Source for single gallons of Mobil Vactra #2 Involute General Metalwork Discussion 2 04-05-2007 01:02 PM
