Old 11-01-2010, 05:03 PM
fuper is on a distinguished road
Machine/tool Recommendation
I hope this is the correct forum.
I live in an apartment and I have the occasional need to cut square/rectangle pieces from plastic [no larger than 2-3" x 12"]. Additionally I need to do a few drill holes but they need to be precise.
Can anyone recommend a minimal set of tools for the job? Are there mini drill presses that you recommend for a dremel etc?
Cheers,
Fuper
Old 11-08-2010, 04:01 PM
florida is on a distinguished road
fuper, what is your current method for cutting the plastic? is it soft enough to score with a knife or are you sawing it somehow?
Old 11-08-2010, 10:48 PM
Hey thanks for the response. I use a razor blade, score it then snap it. I'm using various plastics as I buy my pieces as scrap from Tap Plastics. Scoring really hurts my hands and I would like more precise cuts.
I was looking at a small bandsaw. Would be useful for cutting thing sheet metal as well?
Old 11-09-2010, 06:53 AM
fuper,
You will likely lose some accuracy with the bandsaw, and its not the best for cutting sheet metal. A couple economical investments might be getting started with a standard drill press for holes, and a cutting board for the plastic. Some of the art stores still carry the cutting boards which have a razor blade attached to a rail. After you lock the rail in place, they also have a knob to push the blade deeper so you won't hurt your hands cutting. I used to build architecural models that way. I think after you try something like that, you'll have a better idea of which types of machines you're looking for.
Old 11-09-2010, 10:08 AM
will gilmore is on a distinguished road
how thick is the material? how about a small table saw?
Old 11-09-2010, 01:36 PM
Originally Posted by florida View Post
fuper,
Drill press totally makes sense. I will go check out these plastic scoring machines. I've heard of em but I've never seen one Thanks!
Old 11-09-2010, 01:38 PM
Hi Will.
The material thickness of the plastic is under a 1/4" I never deal with a piece more than 12" square. I live in an apartment so my project sizes reflect my available space
The sheet metal I'm using is just standard stuff you can get from home depot. I can bend it by hand but need tin snips to cut it. Not sure of the gauge.
Problem- 21iT: Using 2 offsets for 1 tool:Machine stops for tool change gnmachine Fanuc 4 02-01-2011 08:10 AM
Need Help!- CNC punching machine recommendation Lowe Want To Buy...Need help! 0 03-25-2009 05:04 AM
CNC machine recommendation Mike Arthur CNC Tooling 0 10-09-2008 04:39 AM
19" table? machine recommendation Sonicmook56 Benchtop Machines 13 09-07-2007 02:09 PM
9 x 20 3/8 turning tool recommendation twocik Mini Lathe 13 06-23-2007 05:32 PM
