Old 10-25-2010, 01:40 PM
greenchair is on a distinguished road
Limit Switches, Toyoda fv45
I am having issues with finding the proper home on my machine and am wondering about the limit switches.
There is one (dog) for detecting the forward over-travel and two dogs at the rear over-travel limits. I am thinking that one on the inside is the home.
However, there is also a dog in the center of the machine travel that also hits a separate contact. I don't' really know what this one is for. Any ideas.
thanks
As for the problem, my machine homes, but the overtravels going to tool change position. I suspect the dog is worn and the home is a bit further out than it should be.
Old 10-29-2010, 08:40 PM
Micah's Avatar
Micah is on a distinguished road
The inside one is typically the home and it's right near the tool change location (y axis in a horizontal mill perhaps?). You should be able to go to the i/o screen and watch the switches turn on/off. Go to the i/o screen and verify that the home switch isn't doing anything funny like intermittently activating/deactivating. When you're at the i/o, move the axis with the hand wheel toward the tool change position (make note of that coordinate for this). Slowly go to that position and check the behavior of the switches. Otherwise, your dog wear theory might have some merit. Have you opened it up and looked the dogs and switches over for anything obvious?
Limit switches and homing switches AeroKam Open Source CNC Machine Designs 16 01-05-2008 07:56 AM
Limit Switches Swisha_House Benchtop Machines 6 11-05-2007 06:02 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
