Old 10-20-2010, 05:17 PM
freemen's Avatar
freemen is on a distinguished road
Arrow Threading ???
2 weeks ago got a phone call to pick up a mill and a lathe for FREE if I could get them out of his garage they were mine all mine !! They had been siting there for 5 years and he told me what you see is what you get, (missing tail stock and tool holders for quick change and 8" 4 jaw chuck and 3 jaws for the 6" chuck) Now, the lathe a King model 1440 and the mill, King model KC-45 so a lathe of 14x40 weighing 1300lbs and a rong-fu 45 of 700lbs had to be moved to my basement. Not to worry got them both in the truck with a fork lift and into the basement with no problems!!
Now for my little question... threading wise as I looked on the lathe there are 2 diagrams for threading and for placement of the gears one says 40T to 120T/127T to 40T and the other is 40T to 127T to 40T so which one is right ???
ID:	117205   Click image for larger version
ID:	117206   Click image for larger version
ID:	117207   Click image for larger version
Hardware: the part of the computer that can be kicked. If you can only curse at it, it's software.
Old 10-20-2010, 06:01 PM
juergenwt is on a distinguished road
Freemen - 40-120/127-40 is for threading metric with an inch lead screw or threading inch with a metric lead screw. 40-127-40 does nothing but change direction.
Old 10-20-2010, 06:11 PM
freemen's Avatar
My lead screw is 8TPI and I did not notice anything metric in the diagrams, and since I don't have a manual with it which gearing placement would be the right one for making 3/8 16TPI ?
Old 10-21-2010, 06:57 AM
PixMan is on a distinguished road
Looks pretty straightforward to me.
As long as you have the gear train going from the two 40T gears through the 127T gear, set the selector knobs to C1 and have at it.
ID Threading roundman Haas Lathes 14 05-27-2010 08:58 PM
MDF threading MrWild JGRO Router Table Design 13 01-01-2010 10:17 AM
C6 Threading. ToolMach_Aust Syil Products 9 08-01-2008 03:52 PM
Help with threading protrxrptr17 G-Code Programing 15 02-19-2008 05:09 PM
Threading with G76 cijunet Mastercam 1 12-18-2007 06:43 PM
