Old 10-19-2010, 09:05 AM
tomcannon is on a distinguished road
Herbert Churchill CNC Lathe, Fanuc Control Advice
I'm looking at buying a Churchill 3/15 twin turret cnc lathe and after some general advice on what they are like as machines. I have been using manual machines for years and this would be my first cnc machine.
It has a GE 2000 TC control, can I expect it all to be reliable and fairly easy to use & programme? I'm 25 and pick computer type stuff up fairly quickly so I have some faith!
I will be using it for making some studs, as well as a few other basic components I currently make on our Colchester. The two 6 tool turrets sound promising, but if they are not known to be reliable it may not be great for me.
Regards,
TC
Old 10-19-2010, 09:47 AM
Al_The_Man's Avatar
The GE2000 control is a very old control, you may have problem getting service and parts when the time comes.
Old 10-20-2010, 09:52 AM
gridley51 is on a distinguished road
I wouldn`t worry about the GE2000 control,I have a few running here and they are rock solid.There are plenty spares about too in England but you can pay £1200 for a bubble board if you need one.
Regarding programming,our first cnc was a BSA twin turret machine with this control and my son who had no experience of programming found it very easy.We have Fanucs,Siemens,Dynapath,Heidenhain and other controls here and he still reckons it`s the most operator friendly.It`s also got features that were unheard of in other controls back then.
That lathe will also have Hiak drives,they too are quite reliable,easy and cheap to repair but don`t like damp.We give them twenty minutes with a fan heater before powering up if they`ve not been used for a while.
BSA may or may not have software that they can reload for you if needed.A phonecall to them quoting the serial number should get you all the info.
I have three Churchills here,two with GE2000 and they have been very good,reliable machines.One of them is a 3/15 but with one turret only.Both these machines have barfeeds on them and are very accurate.
If yours had been a single turret machine I could have helped with a software reload if needed.It`s also quite easy to go into the MSD and edit it to suit what you want to do.
I know of the machine you are interested in,the seller used to post on here sometimes.I will send you a PM,are you set up to receive them?
Mark.
Old 10-20-2010, 10:06 AM
cmobilaah is on a distinguished road
Hey guys!!! New to the site!!! Was wondering if anyone knew where to get a copy of the ez guide fanuc software for lathes that i could use on a laptop or any thing sort of similar. I´ve just moved to a new country and finding it a little hard with the computers being in a different launguage. Would be a huge help to me to help me get off my feet.
Cheers Cmobilaah!!
Old 10-20-2010, 10:09 AM
Mark that would be awesome, great post many thanks.
TC
Old 10-20-2010, 10:55 AM
Tom,PM sent.
Mark.
ikegai fanuc fx lathe 5t control caddyshack 5T/5M 20 11-19-2011 06:39 PM
Lathe with fanuc control, need help Adaware Fanuc 4 06-04-2010 02:05 PM
Need Help!- Homma lathe with a Fanuc 10 control drtaz Fanuc 0 02-25-2008 03:54 PM
Fanuc 10T on Matric Churchill F.Sharifi Fanuc 1 01-07-2008 05:12 PM
Herbert Al30 Help turbo bob General Metal Working Machines 1 06-07-2007 04:47 PM
