Old 10-18-2010, 02:11 PM
dlange is on a distinguished road
Aluminum Speeds&Feeds
Alright
I haven't had much luck with these calculators from different websites, Take your pick, american machinest, Gwizard.. so on
The machine I use reads in IPR along with RPM
To have a nice finish I've come to such conclusions as
For example with 6061 Aluminum
cutting through a thickness of .135" with one pass for nice finish works to
850 IPM 14K RPM single flute. which give me an IPR of .061
cutting through a thickness of .350 with one pass, milling out ward
same.. one pass for nice finish works out to
2800 IPM 14K RPM single flute. which gives me an IPR of .2
My question.. Are these IPM numbers irregular? Are the RPMs irregular. I'm trying to see if I'm doing something wrong or missing something.
Thank You!
Old 10-18-2010, 03:00 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Are you saying you are feeding at .2" (5mm) per revolution with a single-flute cutter?
5 cuts per inch in other words. That is an amazing tool if it is giving a good finish.
DP
Old 10-18-2010, 03:11 PM
yes
yes that is correct. I can go slower and get a good finish but its not shiny, its not reflective at all.. almost like the aluminum chips just push themselves into the cut. I am completely new to this.
I have learned quickly that speeds and feeds are one of the hardest things to figure out in this CnC world. I some how have to go fast enough to where the cutter isn't going to break, there isn't a lot of vibration, and a clean, reflective finish is left over.
Here is a picture of the tool
I believe in this picture an 8mm is shown, I'm currently using a 12mm same style.
PEACES!
Old 10-18-2010, 03:20 PM
What is the traverse range of the machine?
DP
Old 10-18-2010, 03:27 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
the best thing to do is contact the tool manufacturer and get their recommended feeds and speeds
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 10-18-2010, 03:40 PM
range
I want to say traverse range is 24 inches but I could be wrong.. I mean, I am a total newb with a tape measure.
Dertsap.. already done it, awaiting the e-mail :-)
Old 10-18-2010, 03:51 PM
So, is that the range in X, Y or Z? What is the largest job the machine can do? Just give us a rough estimate in all three axes.
DP
Old 10-18-2010, 04:45 PM
DP
Looking at 141 inches for X axis, 24 inches for Y axis, and 24 inches for Z axis
And I just cut with a 2 flute helical downcut 3/8 end mill, what a beautiful shine ran it at 15k RPM with .133 IPR feed
Old 10-18-2010, 04:50 PM
Heat
I'm still not 100% comfortable with these speeds and feeds because I run over to the tool after the cut and feel it, and there is quite a bit of heat staying with the tool, so thats telling me the heat isn't staying with the chip.. same 15K RPM .133 IPR feed
Old 10-18-2010, 04:55 PM
So - from corner to corner of your X Y traverse is 143 inches.
You are feeding at: - 15000 revs per minute x .133 inches per revolution = 1995 inches per minute.
Your cutter will feed from one corner to the opposite corner in 4.3 seconds.
Does that sound right?
DP
  #11   Ban this user!
Old 10-18-2010, 04:58 PM
Well
Right now I'm just cutting circles out of aluminum.. Would it go corner to corner in 4.3 seconds.. that sounds about right, its moving pretty quick while cutting
My day is over, talk to ya'll tomorrow bright and early!
-D
Old 10-18-2010, 06:18 PM
dertsap's Avatar
Gold Member
thats going to be a mighty large chip/tooth
Help Please Feeds and Speeds mtcnc General Metal Working Machines 2 01-21-2010 03:36 PM
Problem- Feeds and Speeds mtcnc General Material Machining Solutions 3 01-21-2010 03:34 PM
MDX Feeds and speeds and aluminum oh my!? xesxes Benchtop Machines 9 12-22-2009 09:15 AM
Problem- FEEDS AND SPEEDS CORBIN92087 General Metalwork Discussion 2 06-30-2009 09:42 PM
Need some help with speeds & feeds ldkell_2000 General Metalwork Discussion 6 03-01-2008 10:35 AM
