Old 03-11-2003, 09:07 PM
HuFlungDung's Avatar
Moderator
My lathe retrofit
As a point of general interest, I wanted to tell you all a little bit about a retrofit I completed last year. This is perhaps a little bit more expensive than the typical hobbyist would discuss, but as far as I am concerned, my machining business is just a "hobby gone wild" anyway
10 years ago I bought a Graziano lathe that was already retrofitted with a Bandit 1 controller. This was my very first escapade into cnc.
That controller was old when I bought it and I managed to resusitate it several times, but I finally bit the bullet and decided to redo the control with a PC based CNC called CNC Professional from CamSoftCorp.
This was quite the undertaking for me, as I live in a rural community in north-eastern Saskatchewan (Canada) and there is no technical help available in this community. I am the cnc guru here, I guess
Anyways, I got the rewiring done, I reused the existing servo motors, I simply replaced the X axis encoder with a high precision Sony magnescale ( .00005" resolution) to improve the positioning accuracy. The precision required on the X axis is much higher than Z of course, so I thought this would save me some money, just souping up the X axis.
The software I first started out with from CamsoftCorp was actually the cheaper version "CNC-Lite" they call it, but I later found that some of the features that I wanted to have required the more expensive CNC Professional package, so I upgraded.
I purchased a 3 axis 1832 Galil motion controller card and interconnect box from CamSoftcorp. I had an old 300mhz PC laying around which I used for the controller, I later upgraded that to an AMD 550 which is what it currently uses.
Then I got into writing logic for the user interface. Although their software packages ships in a "ready to run" state, it wasn't as safe or as foolproof as I wanted. The great thing about getting this PCbased cnc, is that I could rewrite and modify the graphical user interface to do whatever I wanted. This was a great treat for a tinkerer like me.
So I wrote logic and tested it at the machine off and on for about a year and a half, before I got everything close to perfection. I estimate I spent 500 hours on the project, but the results were worth it. I use the machine to this day, and I am very pleased with it. Best of all, it is fool-proof enough that it makes an excellent trainer lathe for a novice. I've designed every safety method I can think of into the logic, so its almost hard to make a mistake using it.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!Share on Facebook
Old 10-27-2004, 01:13 PM
VooDooMan is on a distinguished road
Hey man nice to see you posting your early years success............I am also clad to see some Canadians aboard!
I have not posted here much in posted in a long time, but since I just bought a new lathe, it is time to make it CNC capable!
I am over in Canada BC................Any way its a clausing 1500 15 swing 48 centers, LOVE this machine and since business is picking up real good on my end its time to do some serious production.!
Can we maybe sit down and chat some more on yur experiences, I am not new to CNC but I am definetly new to servo systems and such, Dont really have any idea where to start, leave my old lead scrws or change to ball screw, Every thing is money sadly
Thank you cya
Old 10-27-2004, 03:57 PM
Moderator
Hi VoodooMan
Yes, it can be a tough decision to decide whether to retrofit. When you are looking at buying things like precision ballscrews, and a Camsoft cnc controller and servos, it can easily cost 10 grand, plus your lathe. It will suck up a few of your working hours, too.
It might be a little more than you'e want to spend, but I'd take a look at the Haas TL1 lathe. If you are more concerned with being able to run the machine, rather than retrofit it, this one's ready to go, and still gives you a nifty measure of "man over machine" control. I had a guy demo one at IMTS and I was fairly intrigued by it. Its not all closed in like a full cnc, but for a guy who doesn't want to program every cut, I think this would be a good entry level machine. If I had some spare change, I'd buy one just to play with it and see how useful it would really pan out to be.
I think some other forumers have bought one of these machines, so I'd like to hear their feedback about it.
Old 10-27-2004, 05:15 PM
Very good point, but now sadly I am going to have to stick to retrofit, Quality isnt that big of a problem, since production isnt always going to be done, rarely on some plastics will I need CNC, but I love the freature!
The lathe was almost 4 grand and has paid it self 50 times over...........I still dont want to get in over my head with this retrofiting, but I am going to keep it under 1.5 thousand $, I have seen it done successfuly, with some time invested, searching for good deals is what takes up most of the time
Perhpas we can step into private chat through email, and I can pick your brains a little bit? What do you say to that offer heheh!
Thank you again!
Old 11-04-2004, 02:36 AM
Piobaire is on a distinguished road
Beginning of an lathe retrofit
Hi there!
I'm just in an early stage of rebuilding an 1985 Harrison M400 CNC (8"x60") with a new PC-based controller from Ajax CNC. The old Anilam Crusader IIL have done its job a long time a go, that's why I got it quite cheap. A 4-position tool changer also came in the deal.
First of all, the cross slide table where worn as lack of lip seals. I'll make a new table and also increase the ball screw height in the slide to fit in a standard sized ball nut and better bearings. The servo is originally fitted in front resulting in that the operator is placed too far from the machine. I'll also change the x-axis servo to fit in the opposite side to earn space.
The servo for the z-axis is a bit in the way for the slide so the travel length in z-axis becomes a bit limited. Hopefully I'll come up with a nice idea to move that to, avoiding the two servos to collide.
Then I plan to build a new controller box a bit like the new Harrison Alpha series that could slide on the front with two hand wheels to run the machine in manual mode. I already got a 15Hp frequency inverter to control spindle speed.
Send rough pictures of "before" and "after" very fast sketched in SolidWorks.
Is there anyone with experiances regarding DC servos, DC servo drives, Ajax CNC, rotary encoder placement, lathe design for best performance and accuracy etc. pleas feel free to email me.
Best regards
/Thomas (Sweden)
Name:	harrison m400 original.jpg‎
ID:	3861   Click image for larger version
Name:	harrison m400 rebuild.jpg‎
Old 11-04-2004, 10:52 AM
any spare equipment you can let go from your old CNC, any thing working at least?
Thank you
Old 05-01-2006, 03:14 PM
r1656 is on a distinguished road
Hi
Im interested in the parts you used to retrofit your sag 12 and as many photos as you can send so I can see what it is you did to accomplish this feat. Russ Please send to r1656@aol.com I sure appreciate it and it would make my project much simpler looking at what someone else did.
Old 05-01-2006, 06:04 PM
Moderator
Russ,
I don't have detailed pictures taken during the retrofit stage. Its all together now, and it is difficult to make out too much.
My lathe actually was a re-retrofit, so indeed, some previous owner had already gutted the quickchange geabox, apron, and installed the ballscrews and servomotors. So I started from that point, replacing the control was my main headache.
I'll take what pictures I can. A lot of the good stuff is buried under covers and such....
Old 05-01-2006, 07:22 PM
Al_The_Man's Avatar
Hu, Did you ever get the Threading routine down pat? Was it using native Galil commands?
Old 05-01-2006, 07:32 PM
......I think some other forumers have bought one of these machines, so I'd like to hear their feedback about it.
Could not be happier. I bought one to use for developing new parts and making tooling. Now I am reluctant to go to any of the manual machine even just for facing something. I have been impressed with the rigidity of the TL and have uploaded two pictures showing before and after shots of a shaft about 8 inches long done without a center or any support. The only minor complaint I have is that the rapids and tool changer are very slow so it is not really suitable for doing much by way of production involving all four tools.
ID:	17739   Click image for larger version
Old 05-01-2006, 07:55 PM
Moderator
Al,
Nothing has changed in that department, since I'm all out of ideas to make it any better I do still run the threading via a Galil program directly on the card. It never mucks up tracking the original thread groove, no problem there, but sometimes I wonder if the thread tool is ever going to move, then suddenly the machine will see the encoder pulse and it will seem to take several passes just as quick as can be, with little delay.
I'm still thinking that it just a matter of synchronization, and the Galil card is just not looking for the input continuously, but is rather sampling the input. So in the short timeframe allowed, with the encoder running at quite high speed, it misses the right interval to take the sample and see the signal.
My reason for my theory, is that I am running the Galil card at nearly as fast an update rate as is allowed, plus I have the spindle encoder running at 1/4 of the spindle speed. This seemed to be the best fit for this hardware, although an even greater reduction in encoder speed might be beneficial. But, I thread typically at 800 rpm, so the encoder is only turning at 200 rpm now.
  #12   Ban this user!
Old 10-02-2006, 08:18 PM
CATCH22 is on a distinguished road
graziano
HU im curious i just bought a sag12 and the transmission cluthes are slipping. do you know if you are still using the trans or are you just using the motor with a vfd. thanks catch.
Help me buy my first Mini Lathe Highfly Mini Lathe 20 05-10-2005 03:07 AM
Large lathe retrofit Fabric8r General Electronics Discussion 6 03-12-2005 11:12 AM
OneCNC XR Series Lathe CAD/CAM Released: OneCNC Product Announcements & Manufacturer News 0 03-07-2005 05:20 PM
Just got a taig lathe. anoel Mini Lathe 2 01-18-2005 05:29 AM
non-circular lathe turning Help! oldguy General Metal Working Machines 2 04-06-2004 12:55 PM
