Old 10-15-2010, 12:00 AM
chris123 is on a distinguished road
ER16 ATC... does it exist?
Hello,
Does anyone know where I can find an ATC for my taig with ER16
Old 10-15-2010, 06:57 AM
Fastest1 is on a distinguished road
I have tried the IMS toolchanger. If you are cutting foams or soft wood, maybe it works. It did not work for me and the tool holder spun in the holder. Calling IMS< I was told the spring pressure was too low. I had to buy a new spring. Though it did hold tighter, it still slipped and when the tool slips it breaks. In my research I did come across this link, USOVO.de - Werkzeugwechsel Spindel fr Sherline 5000er
This looks like the best system I have seen so far besides Joe Vicars system which is no longer made (some parts are available but not all).
I have a Dyna 2400 and it was available with ER16 quick change tool holders. Looks like a baby cat 30/40? the retention nut when unscrewed pulls the tool holder out. Works very well but no tool holders are available. It would not work for automatic changes but works very well for quick changes with no use of a drawbar or hammer to remove tools.
Old 10-15-2010, 08:58 AM
So in other words, not really?
I like the joe vicars system, has anyone used it, made it?
Old 10-15-2010, 10:42 AM
BTW I was having problems in metals with the IMS not in woods and foams. What wouldnt work about the spindle I just linked you to? Air solenoid of some form to trigger the tool change.
Old 10-15-2010, 12:59 PM
The Blight's Avatar
The Blight is on a distinguished road
Just making sure: You have seen the Taig conversion of the joe vicar ATC?
Old 01-04-2011, 07:31 AM
Herbertkabi is on a distinguished road
Usovo SK15 toolholder (ER-11 collets) has the same size and 8 degree angle as ER-16 collet, fits exact in to ER-16 chuck.
I have bouth two items from Usovo - ATC for Sherline and Toolchanger Spindle WZW105 (bought without motor, I made and installed myself) + 6x toolholder box ...
Sherline ATC has spiral spring, 75mm free lenght, 17.9mm OD, 10 turns from 1.6mm steel wire, when air in then spring lenght is 22mm -> when holding then ca 28mm.
Air cylinder/piston 20mm diameter , 3.14 cm2, that means when 6 at pressure then force to piston is 18.84 kg. Holding force I did try to measure with dynamometer was only ca 9 kg when spring pressed to 28mm.
Main problem by my opinion is how the first part of shaft is connected with cilinder (with second part of shaft) ... 20 mm OD part goes into 20mm id and fixed with three 4mm set screws ... nothing more ... oh yes, Loctite of course.
Im not sure what will be come when a little bid bigger force acts to spindle during milling protcess, some little mistake or too hard milling ...
ID:	123036   Click image for larger version
ID:	123037   Click image for larger version
ID:	123038   Click image for larger version
Old 01-05-2011, 07:56 AM
Perhaps someone does not understand how it works.
Air pressure comes in to spindle housing. Both bearing has thin washer from inner side, air pressure does tight these washers to bearing.
There is one very small air-channel inside piston/grip (on the centre of piston)
from where small amount of air can go out through for cause pressure unbalance on the piston sides, this channel is adjustable with tiny screw ...
cheers,
herbert
ID:	123110   Click image for larger version
ID:	123111   Click image for larger version
Old 01-06-2011, 04:55 PM
Problem: its sherline not Taig as stated in OP
Old 01-07-2011, 09:05 AM
rowbare is on a distinguished road
Guess that answers your question.
Did you see this? They have an adapter available for Taig mills. But the price!
http://www.cnczone.com/forums/produc..._sherline.html
bob
Old 01-07-2011, 09:17 PM
What a joke... that costs about half of a new very large desktop machine
Does this kind of thing exist? Involute Laser Engraving & Cutting Machines 1 02-10-2010 11:31 AM
Does it exist? stevespo Servo Motors and Drives 3 05-05-2009 08:36 PM
Does this software EXIST ? ZipSnipe General CAM Discussion 16 02-15-2007 07:38 AM
Just curious does this exist ? ? ? scratch_6057 General Electronics Discussion 13 03-18-2006 01:09 PM
Do IMService actually exist? Linus DIY-CNC Router Table Machines 3 09-02-2004 10:02 AM
