Old 10-11-2010, 09:42 AM
mattslay is on a distinguished road
Need help finding specs for DIN 332-D M12 center
I have wasted so much time search the internet for the geomerty specs of a center in the end of a shaft designated as "DIN 332-D M12". My customer has provided the drawin with this spec on it, and he has no information on what it is, and I cannot find it anywhere.
Can anyone please point me to where I can find complete specs (angle, c'bore dia, depth, thread depth, etc.)
Old 10-11-2010, 10:50 AM
My AutoCad has DIN 332-A, -B, -C & -R but no -D. I thought I could print it out and measure it, but no luck.
Dick Z
DZASTR
Old 10-11-2010, 12:48 PM
juergenwt is on a distinguished road
Mattslay - DIN 332 -D M12 is listed Under DIN 332 T 2. To get all the dim.s you need to get DIN 332 Part 2. It is a center with straight (straight 60 deg) flutes and 10.2mm dia at the first point and 13 mm on the second step. Listed as 60 deg. center with thread for shaft ends on electric motors. No protective c/sink.
Hope this helps you. Juergen.
I found this:www.b-aer.de/pdf/seite045.pdf
It should give you all you need. View in the upper left gives you the dim's for the center drill DIN332, Type D, M12. The smaller dia guides inside the thread, the next dia clears out a part of the thread.
Old 10-16-2010, 12:37 PM
Added note ; The smaller dia. IS the tap drill. In your case for M12 it is 10.2 by 28mm long (L 2).
finding center of a hole BeerFizz Mach Mill 1 06-14-2007 07:17 PM
Help finding specs on Vexta Stepper scratch_6057 Stepper Motors and Drives 1 01-11-2007 12:56 AM
Finding the center Tazzer General Metalwork Discussion 6 08-05-2006 12:18 PM
Helpme finding this specs pls..... Calico Stepper Motors and Drives 0 07-10-2005 10:40 PM
need help finding specs on motor CNC Darren Stepper Motors and Drives 11 05-21-2005 11:41 PM
