Old 10-11-2010, 07:57 AM
prash is on a distinguished road
fanuc OT threading problem
FANUC OT :While threading;first two cuts are OK but the third cut will spoil the work done by previous 2 cuts (in other words the start position of tool will be changed third time).
Turning of the machine is OK.
All the pulleys, encoder, ball-screw and other suspected mechanical parts have been replaced already without luck.
The same program works fine with other machine.
Parameters are original (not changed).Checked several times.
In summery:Program,Parameters,Mechanical parts and Encoder are OK.
What spoils threading after second cut?
THANK YOU ALL.
Old 10-12-2010, 12:44 PM
gridley51 is on a distinguished road
Are you running a canned cycle?
If so which one?
Does it thread ok if you programme it longhand?
What machine is it?
Old 10-20-2010, 11:50 PM
wmpy is on a distinguished road
I had this problem before on a machine where the belt between the spindle and the tach was slipping.
Also, could your part be slipping in the collet or chuck?
Old 10-21-2010, 09:40 PM
@gridley51: I am not a programmer. I am man of electronics.The programmer says he checked all G codes and the program which he uses for this machine works OK with other machine.I will get the program from him and post it. (currently I am on another project ). @wmpy:Slippage !! Well mentioned.will have to check this.
Thank you both for reply.
Just IN- G78 Threading Problem bigmantate Europe Club House 0 09-07-2010 01:10 AM
Need Help!- Miyano fanuc 10t threading problem bruiserba Fanuc 2 12-29-2009 05:47 PM
Newbie- STAMA MC320 threading problem (Fanuc OM) diz Fanuc 1 04-14-2009 11:55 PM
threading problem girishnadkarni Fanuc 6 08-29-2008 05:22 PM
