Old 06-22-2005, 12:20 PM
Ubarch is on a distinguished road
Another thread about purchasing advice
Hello,
Probably one of the most popular topics. I've done as much research as I can regarding mill operation and such, but I'd like the opinion of people who have made major investments into this type of equipment.
I can probably afford the Sieg X3, which is about 300lbs. This is a more or less manageable weight. I can also afford the "Gearhead Mill" for sale at Harbor Freight which weighs 625lbs, which might not be manageable. Can you usually take these things apart to move them? Should one buy the biggest block of iron fromt he start, or start smaller?
Thanks.
Old 06-22-2005, 01:33 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I have never heard of anybody complaining that their machine is too big (unless it is worn out or they have to move it).
I would suggest buying heaviest machine you can afford at the time, but I guess it depends on what you plan to do with it. If you are cutting balsa and foam, then go light but if you plan to machine steel and other metals, go heavy. I have seen the HF machine and I don't think it would be a bad move. With some TLC it would be a good start, but I do not have first hand experience with it. Taking it apart to move it would give you a good chance to clean it up and make required adjustments as most of the made-in-China machines are a bit sloppy and disgusting right out of the box.
Have fun!
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 06-22-2005, 03:09 PM
Sounds like good advice. You're right that the Sieg X3 is a safer bet in that so many people have bought that very model and reviewed it.
The original plan was to purchase the mill specifically to fit it for CNC. However, I've run into great circumstances. My work would like a desktop CNC, they have surplus servos that are more than adequate, and have paid for the necessary electronics. I can make an alpha version of a desktop CNC on their Sherline equipment, then learn from the mistakes I'll inevitably make on those before going to work on my home project. In the meantime, it can't hurt to get the mill and become familiar with it. See, my background is in electronics and programming, so I think I'm approaching CNC from the opposing side, comnpared to those approaching it from machinist backgrounds.
Thread mill programming software? cncwhiz G-Code Programing 6 12-31-2008 01:48 PM
Thread milling, can anyone help jtrav General CAM Discussion 16 03-06-2006 02:25 PM
Purchasing Steppers - Advice please andy_ck87028 Stepper Motors and Drives 21 07-19-2005 05:32 AM
GHT thread Flyinfool General Metalwork Discussion 5 07-12-2005 02:49 PM
Thread milling cutterdia / hole ratio HuFlungDung Machine Problems, Solutions , Wireless DNC, serial port 3 12-31-2003 08:44 PM
