Old 10-05-2010, 08:42 AM
cnc312 is on a distinguished road
siemens ELG problem in Pfauter PE150 cnc
hi everyone.
forgive me if I posted this topic to wrong sub-forum.
CNC brand : pfauter PE150 with siemens electronic gearbox(ELG)
I need to enter parameters for ELG.
but I didn't find any menu to enter this parameter.
I found some manual , but they were not useful.
I need the menu that contains ;
-machine data
-setting data
-sevice data
but I didn't find this screen.
please help.
Old 10-07-2010, 06:38 AM
M.RISHIKESH is on a distinguished road
Need Help - Siemens System 3
Dear All,
KINDLY LET ME KNOW HOW TO POST THREADY RELATED TO SIEMENS CONTROLLERS/CNC SYSTEM
We have got a Grinding Machine with System 3 of Siemens
When we connect Siemens Field PG with 511 card of CNC rack through Step 5 cable of Siemens, PLC is not going ONLINE.
If we detach the cable then we get message AS511 interface not connected with PG that means cable is alright
We tried by changing PLC CPU & then did Cold Restart by putting PLC CPU switch in Stop Mode, pressed Rest on Power Supply and Restart on PLC CPU, released Reset of Power Supply then when Green Run LED of PLC CPU gets ON and Off, released Restart of PLC CPU, moved Switch from Stop to Run on PLC CPU, once again Stop to Run , PLC comes to Run mode but PLC is not getting ONLINE with Field PG
Same case with other PLC CPUs also
Can u kindly advice for the above ?????????
Best Regards,
M. Rishikesh
Using Siemens erdinct Siemens Sinumerik CNC controls 4 03-23-2011 09:34 AM
Need Help!- File transfer problem with Siemens BNR_RANDY General CNC (Mill and Lathe) Control Software (NC) 5 08-28-2010 10:37 PM
Siemens sinutrain problem darkreaperz General CNC (Mill and Lathe) Control Software (NC) 1 06-09-2010 04:35 AM
Siemens NX 6 malcolmx Spanish CNCzone 2 03-23-2009 04:35 PM
Siemens drive problem bigtomt Machine Problems, Solutions , Wireless DNC, serial port 2 02-27-2006 07:38 PM
