Old 06-20-2005, 08:59 PM
Gold Member
JFettig is on a distinguished road
4x6 bandsaw motor fried, UPGRADE!
I was milling and cutting metal, metal jammed between the stop and the blade and toasted the stock motor on my 4x6 bandsaw from HF, I hated that motor, was really hot running and just crappy overall. I was searching around and found this sweet motor:
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Only costed ~$16 to ship! sweet upgrade. The only thing is that I cannot fit the belt cover on and its huge, I need a new eye ring screw thats a little longer. I cannot stall this motor so far, blade keeps falling off.
If you know how to fix the blade falling off problem, let me know I got a bimetal 6-10 variable pitch blade on this.
Jon
ID:	8284   Click image for larger version
ID:	8285   Click image for larger version
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
Old 06-20-2005, 11:31 PM
ViperTX is on a distinguished road
Jon, what was the rpm of the HF motor....I have the same saw....still boxed....but I'd like to pick up a spare motor. Thanks, Paul
Blade falling off.....this uses a regular band saw blade...so I would suspect misalignment....also if you stalled the motor...you may have put a bend on the blade...which would also cause problems.
Old 06-21-2005, 06:02 AM
Gold Member
The motor has the same rpm specs, 3450, reversable rotation.
I am thinking misalignment too, will take a look later.
Jon
Old 06-21-2005, 10:14 AM
anoel's Avatar
anoel is on a distinguished road
If you still have the manual... It explains how to adjust the tracking...
There's a bolt on the sliding part of the tensioning mechanism. That's where the adjustment is made.
I have the same saw and I concur that the motor is truly a poor motor. Like you said Runs very hot and stalls very easily. I'm just holding out for a good cheap motor to pop up for me to grab,
Nathan
Old 06-21-2005, 07:12 PM
Gold Member
anoel, that motor I linked to at ebay rocks, you should seriously grab one up. I looked around surpluscenter, and the cheapest similar motor was over $100
Jon
Bandsaw accuracy? gtslabs General Metalwork Discussion 3 12-29-2003 09:26 PM
Can you cut Al. with a wood bandsaw CactusChip General Metalwork Discussion 5 11-20-2003 03:45 PM
