Old 10-03-2010, 09:45 PM
jimmyaz is on a distinguished road
Smithy 1220LTD lathe (center drill off ceter issue)
Hey Guys.
I recently bought a Bolton, supposely it a clone of the Smithy 1220LTD. Everything seem to be ok, but today I try some center drilling on the lathe. I have a .238 bit and I need to drill a 6mm shaft. When I use my drill press, the hole is prefect 6m and fit on a 6mm shaft snug. But on the lathe, the hole is probably 6.10mm, causing slop when I put over the motor shaft....
From what I can tell, the chuck is running center and smooth, I put on nice steel rod and you can't even see it spinning.
What do I adjust for how to fix this?
Problem- 1240 Smithy axis lockup issue jeff 888 Smithy 4 09-22-2010 10:48 AM
Center Drill Drill Depth bowersjack General Metalwork Discussion 4 01-28-2008 08:53 PM
Smithy 1220ltd kenlambert Smithy 2 01-19-2006 09:10 PM
Do I need to center drill? jderou General Metalwork Discussion 9 06-15-2005 09:33 AM
