Old 10-03-2010, 10:51 AM
jesuscowboy is on a distinguished road
Help with Spline
Have couple questions about splines; trying to reverse engineer a part. I know very little about machining but have a friend with CNC Machine shop; and I can use equipment for free. I am trying to build part like pic. Few Questions:
1)How do I know if part is involute or straight spline
2)If I knew what broach to get could I cut 6 and 10 spline internal by cutting one spline at a time then rotate to do next spline or would I need a broach that did all splines together. From my understanding a broach like this would be $$$$$$$$$
4)As far as the 40 spline sections I plan on using mark williams
http://1.bp.blogspot.com/_N5raeDVd7b...+coupling1.bmp
Old 10-03-2010, 07:44 PM
christinandavid's Avatar
christinandavid is on a distinguished road
You need to attach your pics in a way they can be enlarged. The internal looks straightforward, can't tell if the external is involute or not, but if it engages with some other cogs/gears then it probably is - look at this: -
Involute gear - Wikipedia, the free encyclopedia
As you can see this is a complex form and you would need a bespoke piece of tooling to produce it. You also need to know the relevant dimensions of the mating parts to determine the shape of each involute arc.
If the parts are very large (ie big enough to poke a milling head attachment into - can't tell from drawing) then the internal spline could be milled. Not the best way if you require job to be done with high accuracy though...
If components are small you need some kind of slotting machine - or better, a proper gear-cutting hobber - and the cutter profile you use will depend on that machine's capabilities as well as the other constraints of money/time and finish/accuracy required.
Of course you could clamp a basic tool directly to a spindle head/turret and use a CNC mill/lathe as a slotter if your friend doesn't mind...
DP
Old 10-03-2010, 08:58 PM
sorry about size of pics but internal spline approx 1 3/16 outside spline is 1.7083 major diameter and would be cut using 45 degree from mark williams. The 45 degree pressure splines are not really the problem b/c MW does these pretty cheap like $150. My concern is cutting the inside splines I have seen broaches go for as little as 50-60 bucks. I would rather do the 10 spline and six spline part myself just wondering if I can get the proper measurements and broach can I do this with indexing head and CNC Mill or even a press. I'm more intrested in the process. I may end up making some of these for sale and if I had the broachs for 6 and 10 spline I could send the other out to Mark Williams. If this can be acomplished with single spline broach and I could get broachs for few hundred bucks I would rather do it that way. I just have no idea about the process and tooling cost. I know multispline broaches are hella expensive. As far as that goes if broaches are as cheap as I have seen some on ebay I would buy one for the 40 spline part and spend several nights at shop turning an indexer. Also if that were the case how much would a cutter be to do the outer 40 spline. The way I figure if I could spend 500-600 on tooling I would do it all myself.
Old 10-03-2010, 10:09 PM
Try Grob, Inc. - Industrial Band Saws And Cold Rolled Metal Products might be helpful. Click on cold rolled products.
Dick Z
DZASTR
Old 10-04-2010, 12:19 AM
Dick Z
That looks like exactly what I wanted I sent email requesting quote hopefully since they have what I want on the shelf won't be too expensive.
Anyone offer help on broach for 6 spline and 10 spline part in above pic I would give some measurements but don't know what to measure other than diameter.
Old 10-04-2010, 03:38 PM
6 spline appears to be straight spline.
1.) How wide are the spline slots?
2.) What's the width across the bottom of spline slots?
3.) what's the inside diameter of the bore?
Dick Z
DZASTR
Need A Quote- Take a look spline job turboless Employment Opportunity 0 05-21-2009 10:04 PM
Problem- mastercam and spline zewanil Mastercam 4 05-02-2009 12:16 AM
RFQ spline broaching timmydabull Employment Opportunity 13 10-05-2008 06:51 PM
spline help,mc9.1 GRANDPA Mastercam 10 03-10-2007 06:00 AM
Spline scottsss Autodesk Software (Autocad, Inventor etc) 13 07-14-2003 10:30 PM
