Old 09-29-2010, 06:26 PM
jasondaniell is on a distinguished road
Turning Long Aluminum Tube
I am needing to turn a 44" long aluminum tube that is 2.5" in diameter. I need to be able to turn the entire length, so I'm planning on using a mandrel collet on the chuck end and a live center on the other. There is currently about .050" of runout in the part that I need to cut out. My lathe is a Haas TL-2 with a 2000 RPM spindle. I will be using Seco KX polished inserts. Any suggestions on whether or not my setup will work and suggestion on cutting parameters? Thanks in advance.
Old 09-29-2010, 06:49 PM
Cruiser is on a distinguished road
You didn't mention the wall thickness of the tube, It may want to sing like a tennor and chatter like a *****. We had to stuff them with rubber footballs to try to dampen the harmonics. Its going to be all about getting a ballance with the tubes harmonic tendencies.
Don
IH v-3 early model owner
Old 09-29-2010, 07:07 PM
You really need a traveling steady, that length and that diameter is going to be very springy. If you are going to try it without a steady filling it with sand or something, as suggested, may help. Use low rpm and reasonable feed, 500rpm and 0.01" per rev maybe.
Good luck.
Old 09-30-2010, 08:33 AM
The wall thickness is .375. I may try filling it with something to help absorb vibration. I've never tried that before so do I have to be careful to get it completely full in order to prevent the filling from acting like a counterwieght?
Old 09-30-2010, 08:52 AM
I think you don't need to worry about any out of balance effect from your filling because it is a small radius turning slowly.
Before doing any cutting you can test whether your filling material works by tapping the tube with a hammer. If it still rings like a bell it will probably still chatter when cutting. Tap all the way along the tube at one inch intervals and you will probably find the ringing is different.
Lead shot would be the best for vibration dampening but a tube that size and that long filled with lead shot would be heavy.
Old 09-30-2010, 10:45 AM
Or maybe inject high density foam??????? Don't forget a method to remove it later.
This is just an idea. I've not used it, just heard about it.
Dick Z
DZASTR
Old 09-30-2010, 01:37 PM
Cmailco's Avatar
Cmailco is on a distinguished road
Question
No programmable steady rest?
The Manufacturing Reliquary
http://cmailco.wordpress.com/
Old 09-30-2010, 02:31 PM
Unfortunately no programmable steady rest. I decided to cut it in two sections and so far it is working great. I chucked up on it with about 22" hanging out and ran turned that then flipped the part, chucked on what I just cut, indicated it in and ran the second half. No chatter, great finish. Thanks for all the suggestions though.
Need Help!- turning 36" +- .005 long bar nascad General Metalwork Discussion 5 08-30-2009 11:28 PM
pressing aluminum into an aluminum tube Fishin_Rod Mechanical Calculations/Engineering Design 24 07-01-2009 12:23 AM
7.250 long 3" ss tube 3axisrookie General Metalwork Discussion 7 08-17-2008 02:11 PM
RFQ - Aluminum & Delrin turning (Bushings). Possible High Quantity & Long Term LateNight72 Employment Opportunity 13 09-10-2007 01:00 PM
Enlarge internat diameter in long tube. asuratman General Metalwork Discussion 2 04-06-2006 12:19 PM
