Old 09-23-2010, 02:01 PM
dlange is on a distinguished road
Aluminum
This current cut is ran with an 8mm end mill, single flute
14K RPMs
.13 in per minute
The radius of the slot comes out fine for me, but I cannot get the sides to finish up well
Need to get this done with 1 pass... Any ideas?
Old 09-23-2010, 02:44 PM
Are running climb milling or conventional? Is the cutter straight or helical?
You should be able to get a cleaner finish than that running a two or three high helix micrograin carbide cutter climb milling.
Old 09-23-2010, 03:08 PM
So slow
Helical, and both styles of milling, doing a complete oval slot
I'm chaning tools now to a 2 flute end mill
I'll repost
I did get a better finish but I went from that .13 feed rate to a .04
another picture on the way soon
Med-Pac is on a distinguished road
I'd agree with Geof,
A one flute bit is more intended for plastics I believe. How thick are you cutting? It looks like 1/4".
Mike
Old 09-23-2010, 03:29 PM
thickandthin
just over 1/8 .13 of an inch
sliced my finger a bit on the new 2 flute!! exciting!
Picture coming after a few cuts
Old 09-23-2010, 03:57 PM
2 flute
This was at.. 15K going .1 inch per minute
I've brought it up to 18K and ran it slower, all the way down to .04 Still getting these cut marks..
Old 09-23-2010, 03:59 PM
Sorry, the bottom slot is the one in question :-)
Old 09-23-2010, 04:09 PM
Do you ahve the ability to change the direction of the cut? It looks like that is your prob.
Mike
Old 09-23-2010, 04:20 PM
Well.....That's a deep subject
I wish it were that easy.
The object here is to get a clean finish, one pass, that's it. Then I can move on with my life!! LOL
I was getting a more clean finish with single flute... what am I doing wrong here?? The calculation for the machine is [mm/100*g]
I've been told g is for RPM... I don't even use the calculation, I don't know how to get it to work!
Old 09-23-2010, 04:29 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Is it quite loud/vibratey when it's cutting? If those marks are due to vibration then it's going to get worse with a speed up/feed slower/more flutes combo.
The finish may be better in the ends of the slot because the workpiece is stronger in that direction, OR the finish may be better at the ends because the outer point of the cutter is now feeding faster than the programmed feed (actual feedrate = programmed feedrate x ((programmed radius - cutter radius) / programmed radius))). Your control may/may not compensate for this at the ends of the slot. Work out that feedrate and apply it to the straight edges of the slot. See if it helps.
Why finish in one pass? You could use a rougher up the middle of the slot then a nice finisher afterwards to clean up the sides.
If you must use a single tool then reduce the angle of engagement by using a spiral path/pocketing cycle, or a trochoidal path. Chip load will decrease and you will be able to ramp that feedrate right up - it won't take longer and the pressure on the tool/workpiece reduces, lessening vibration/deflection.
DP
  #11   Ban this user!
Old 09-23-2010, 04:32 PM
GENIUS!! I'm putting in the 5mm and trying that right now!!!!
That was my main issue, too much material to take out!
  #12   Ban this user!
Old 09-23-2010, 04:39 PM
One thing that's just occurred to me...If you have limited options regarding toolpath and you want to do it with one tool only - another option you could consider on this job is to rough the middle with the end of the cutter then move down in Z to the fresher/more rigid upper part of the flute to finish the sides.
DP
Securing Aluminum to Aluminum webgeek General Metalwork Discussion 3 12-29-2009 05:30 AM
Bonding aluminum to aluminum - Doable? How? Arquibaldo General Metalwork Discussion 15 11-05-2009 09:01 PM
Carbide endmills Aluminum vs non-aluminum ??? zaebis General Metalwork Discussion 7 09-14-2009 08:53 AM
pressing aluminum into an aluminum tube Fishin_Rod Mechanical Calculations/Engineering Design 24 07-01-2009 12:23 AM
Need A Quote- RFQ: Aluminum CNC bigphil Employment Opportunity 9 08-06-2008 11:11 AM
