Old 09-21-2010, 04:34 PM
new2programming is on a distinguished road
Thread Milling (off center)
I am new to programming as my user name implies. What I need help with is thread milling offset from center. I have some thread milling programs that tell me what numbers to use for a certain size cutter in a certain size hole and how far to travel in Z. Where i am having trouble is my hole is offset in X so I'm not circling XO. The part I am working on is a casting and where I need to thread is on an angle so it is off set in X where my angled hole centerline and the hole centerline that I am entering meet (.3772). I have a 5" 12 pitch thread mill and need to cut 13.375-12 threads. I have to rotate B axis 6.242 degrees, go up inside the casting then cut the threads. I need to circle into my threads make one revolution one full pitch (.0833) then circle out. X is offset .3772 so when I plug the numbers into the program it just gives me what I would need to do circling X0. Right now i am moving X .3772 and feeding up in Y then making one revolution moving Z the .0833 then feeding back down in Y. I want to circle in and out while moving Z an 1/8 or 1/4 pitch. Can anyone help with this? Let me know if you need more info. Machine is Makino a99e with fanuc pro3 controls.
Old 09-21-2010, 07:12 PM
Have you ever used G52?
This lets you set a subsidiary work zero based on your main work zero.
For instance if your hole is offset to X 0.3772 what you do is have the command G52 X0.3772 Y0. Z0. ahead of your thread milling. Now the thread milling does work around X0. because you have created a new offset.
After the thread milling you have G52 X0. Y0. X0. to remove your subsidiary offset.
It is not necessary to include the Y0. Z0. but I do it just to remind myself that I have not used those to create the new offset. Obviously you could use them if your hole is also offset in Y and Z.
Old 10-06-2010, 09:59 PM
maxxbasher is on a distinguished road
You can also move to the hole center and switch to incremental positioning mode (G91) to threadmill the hole. Then switch back to absolute positioning mode (G90) when your done.
Need Help!- SuperMax Turning Center w/ Fanuc O-T, Won't thread UMI Performance Fanuc 3 06-28-2010 04:19 PM
Newbie- Milling Machine vs. Machining Center Question! zenbaby16 General Metal Working Machines 3 05-05-2010 07:31 AM
Thread milling in a machine center jorgehrr G-Code Programing 30 08-05-2007 07:58 PM
0M-Thread milling? mikul Fanuc 1 12-05-2006 11:56 PM
ACROLOC series 10 Vertical Milling Center CNC DieGuy General Metal Working Machines 2 07-20-2005 05:12 PM
