Results 1 to 3 of 3
Thread: Choosing between four large vertical band saws
    Jan 2007
    I'm a home hobbyist who has the need, space and budget for a large vertical bandsaw.
    Need: to cut 1/4" pieces of 6061 into 12" strips with a clean finish
    Budget: ~$3,000.
    Space: No practical limitations, have grade-level access, 240V power single phase; could use 3 phase rotary converter if necessary.
    I've never owned a large metalworking bandsaw like this. Given the nature of my first project, I would think a fence would be crucial to the cut quality. However, only one of the saw's below includes a fence (The G0640x, which is a wood/metal hybrid).
    Here are the four I've been researching:
    1) G0640x - $1,600, includes fence, 3 phase motor with single phase inverter, blade speed of 100-3600 FPM. http://www.grizzly.com/products/17-M...r-Motor/G0640X
    2) G8145Z - $2,600, no fence, 3 phase motor with single phase inverter, blade speed of 108-1800 FPM. http://www.grizzly.com/products/14-1...nverter/G8145Z
    3) SB1021 - Grizzly's "new" Southbend remakes - $3,500, no fence, single phase. http://www.grizzly.com/products/Sout...aw-1-PH/SB1021
    4) A used do-all via eBay, craigslist, etc. (such as http://cgi.ebay.com/doall-do-all-16-...item483a83e772)
    I've held off on comparing the obvious things like throat capacity. Any advice on features, brands, etc is much appreciated. If I end up with one which does not have a fence, I don't see any reason I can't fabricate my own...
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Jan 2006
    If you need a bandsaw I would recommend a used do-all or similar, they are quality units and will last forever.
    Just for cutting aluminum, I would recommend a table saw with a high tooth count carbide tipped blade. The tablesaw will cut aluminum with no trouble and will give you a much nicer finish than a bandsaw will. Just use a little WD-40 or similar to keep the chips from sticking to the blade.
    Matt
    Aug 2010
    I recently was in the same boat as you except I was deciding between used machines. I ended up getting a Grob 4v-18 off Ebay at a reasonable price and I couldn't be more happier with it. I had an issue with the blade welder when the machine arrived. I called and emailed with a Grob rep and they couldn't have helped me anymore and even send me a free manual, and assembly drawings. They even paid the postage. My machine was built in 1979 and they acted like I purchased it from them new just last week.
    To sum it up, my recommendation would be to get a nice used USA made saw that has been well proven and probably hasn't changed designs in 50+ years i.e. Doall, Grob...etc.
    I think I learned my lesson when I purchased a Taiwanese Bridgeport knee mill knock-off rather than and actual Bridgeport. Parts are triple the price if you can find them and no customer service to speak of.
  1. home shops and saws
    By fourperf in forum Haas Mills
    Last Post: 03-17-2010, 08:40 PM
  2. Large band saw construction
    By thespindoc in forum General Metal Working Machines
    Last Post: 05-24-2009, 04:24 PM
  3. cut off saws
    By skippy in forum General Metal Working Machines
    Last Post: 11-23-2008, 03:04 AM
  4. Slitting-slotting saws
    By Vern Smith in forum Haas Mills
    Last Post: 02-27-2007, 12:17 AM
  5. Good band saws..
    By MBG in forum General Metal Working Machines
    Last Post: 11-26-2006, 04:26 PM
